Hi, I need introduce a pause in ARS line. I have an OXO & OXE PBX's conecteed by IP Trunk and this is what I need please:
OXO user dial 599
OXO convert that 599 to 19898
OXE receive 19898 and send a DISA message
Now after 3 seconds OXO have to send 599 to OXE.
The idea is that OXO users dial 599 for finally dial the password needs OXE to be part of the Meet me conference.
Thanks for your support.
ARS Pause
- tot3nkopf
Re: ARS Pause
In OMC help search for "Access to an indirect attendant" --> there is an example
Re: ARS Pause
Yes, I tried with the example but it did'nt work. Furthermore the example is about public call, in this case is with a private call but i tried to reply the example.
Some partners told me that i have to introduce a 'comoditie' inside the ARS line, something like:
599. 19898AAA599
But also, it doesn't work.
599. 19898AAA599
- tot3nkopf
Re: ARS Pause
Try w but I do not think it is working for OXO.
It should work like in the example. Are you sure you have configured everything right?
