MFC R2 Trace?
wonsuk
MFC R2 Trace?
Post by wonsuk »
I make E1 MFC R2 trunk between ACT MG to IPMG.
But It is not work.
I only received below message(incvisu)
20/07/07 14:41:22 000001M|01/19/0/009|=2:0052=Outgoing R2 fault 8 DtEqt 467 Info -1
20/07/07 14:41:24 000001M|01/19/0/014|=2:0053=DDI R2 fault 17 DtEqt 475 Info -1
How can I trace MFC R2 singal?
davidcfy_DUP
Re: MFC R2 Trace?
Post by davidcfy_DUP »
You can do as below:
tuner km
tuner clear-traces
tuner 0 0
actdbg all=off
trc i
tuner appli-trace=on
actdbg mf=on
mtracer -a
try do it. :)
wonsuk
Re: MFC R2 Trace?
Post by wonsuk »
Thank you for your advise.
mejust
Re: MFC R2 Trace?
Post by mejust »
Hello
I tried your trace and yes it worked , but I also want to know the incoming numbers coming from the Operator through thr PCM2 Card.
Can you help me here?
I just see the signaling but I need to know the incoming numbering .
alcatelboy
Re: MFC R2 Trace?
Post by alcatelboy »
Post the trace .some p. can help you.
Sent from my GT-I9300 using Tapatalk 2
AQPS ACFE ACSE
alex
Re: MFC R2 Trace?
Post by alex »
In trace you could see digits dialled.
Something like this:
(644767:323403) MF R2 -- DDI Neqt : 3686 -- Rec. : I-2
(644767:323405) MF R2 -- DDI Neqt : 3686 -- Send : A-1
(644769:323407) MF R2 -- DDI Neqt : 3686 -- Rec. : silence
(644769:323409) MF R2 -- DDI Neqt : 3686 -- Send : silence
(644771:323411) MF R2 -- DDI Neqt : 3686 -- Rec. : I-3
(644771:323413) MF R2 -- DDI Neqt : 3686 -- Send : A-1
(644773:323415) MF R2 -- DDI Neqt : 3686 -- Rec. : silence
(644773:323417) MF R2 -- DDI Neqt : 3686 -- Send : silence
(644774:323420) MF R2 -- DDI Neqt : 3686 -- Rec. : I-6
(644774:323422) MF R2 -- DDI Neqt : 3686 -- Send : A-1
(644776:323424) MF R2 -- DDI Neqt : 3686 -- Rec. : silence
(644776:323426) MF R2 -- DDI Neqt : 3686 -- Send : silence
(644778:323428) MF R2 -- DDI Neqt : 3686 -- Rec. : I-7
(644778:323430) MF R2 -- DDI Neqt : 3686 -- Send : A-1
(644779:323432) MF R2 -- DDI Neqt : 3686 -- Rec. : silence
(644779:323434) MF R2 -- DDI Neqt : 3686 -- Send : silence
(644781:323436) MF R2 -- DDI Neqt : 3686 -- Rec. : I-7
(644781:323438) MF R2 -- DDI Neqt : 3686 -- Send : A-1
(644783:323440) MF R2 -- DDI Neqt : 3686 -- Rec. : silence
(644783:323442) MF R2 -- DDI Neqt : 3686 -- Send : silence
(644784:323444) MF R2 -- DDI Neqt : 3686 -- Rec. : I-7
(644784:323446) MF R2 -- DDI Neqt : 3686 -- Send : A-1
(644786:323448) MF R2 -- DDI Neqt : 3686 -- Rec. : silence
(644786:323450) MF R2 -- DDI Neqt : 3686 -- Send : silence
(644787:323452) MF R2 -- DDI Neqt : 3686 -- Rec. : I-3
(644787:323454) MF R2 -- DDI Neqt : 3686 -- Send : A-1
On incoming call to PABX I-7, I-3 etc - these are digits dialled from PE.
Return to “ON SITE TROUBLES”
