8002-8012 ip sip
telementor
8002-8012 ip sip
hello from greece.does anybody knows if the 8002 set has headset/handset mode in the menu?
- Konstantinos.E
Re: 8002-8012 ip sip
hello mr.telementor
if you go to the portal site you can search the documentation i am sure you can find it there.
I saw from specs that is supported but i dont know where is located in the menu.
kana forum sthn ispania pote 8a pame?? to taxi to plhrwneis esu auth thn fora
Phone only
• Height: 190 mm (7.48 in.)
• Width: 161 mm (6.33 in.)
• Depth: 196 mm (7.71 in.)
• Weight: 810 g (1.78 lb) including handset
• Color: Black
• Adjustable foot stand: 0° or 50°
• Ingress protection (IP): 20
• Redial/Mute
• Local interphony
Display
• One-line, black and white
• 20 alphanumeric characters
Audio characteristics
• Hands-free capability
• Comfort handset
• Volume controls
• Mute control
• Support for G.729 A law/μ law and G.711
CODECs
• Answer from audio equipment
Keys and navigation
(physical keys with LED)
Audio
• Volume control keys (+ and -)
• Hands-free, loudspeaker and external
audio management key
• Mute key
Application keys
• Message Waiting Indication
• Missed Call Waiting Indication
Navigation
• Home key for immediate access to home
menu and dial by name
• ‘C’ancel key
• OK and up/down keys to access menu
¬ Admin settings
¬ Device settings
¬ Call log
¬ Dialing menu
¬ Routing
¬ Local directory
Accessories
• 5-V power adapter (ref. 3MG27026xx)
• Headset (see catalog for latest list)
Power
• 802.3 AZ (Energy-Efficient Ethernet)
support
• 802.3AF Power over Ethernet (PoE)
(Class 1) support (8002 DeskPhone)
(Class 2) support (8012 DeskPhone)
• Maximum power for the 8002 in use
<= 2.68 W
• Maximum power for the 8012 in use
<= 4.15 W (on call and PC connected)
Connectivity
• LAN: 10/100/1000 Ethernet
• PC through integrated 10/100/1000
Ethernet switch (8012 DeskPhone)
• 3.5-mm jack headset port
(8012 DeskPhone)
• RJ-9 connector for handset
• Mini-USB connector for power adapter
Centralized management
• DHCP/AVA
• LLDP-MED extensions for VLAN
assignment and PoE management
• HTTP/HTTPS
• SNTP synchronization
Quality of service
• 802.1 P/Q, DSCP
• RTCP-XR QoS and tickets support: In-call
and end-of-call
Security
• HTTPS for secured HTTP access
• 802.1x Message Digest 5 (MD5)/TLS:
For authentication and management of
customer certificates (with centralized
deployment)
• Denial of Service (DoS) attack protection:
Flooding
• ARP spoofing protection
Internationalization
and localization
• Support for 22 languages
Accessibility
• Hearing Aid Compatibility (HAC)
• Blinking LED for incoming calls (back and
front visibility)
Telephony
• SIP support for telephony services
• Make/Receive call
• Call transfer
• Call Hold/Resume
• 3-way conference
• Multi-line management
• 3rd party call control (3PCC)
• Call log for:
¬ Missed calls
¬ Outgoing calls
¬ Incoming calls
• Dual-tone multi-frequency (DTMF)
• Dial by name
• CLIR/CLID
• Local auto answer (interphony)
Contact management
• Local directory: add, edit and delete
local contacts
• Unified directory access
Advanced communication services*
• Routing management (local or centralized
forward depending on the system)
System interoperability
• Alcatel-Lucent OpenTouch™ products,
including Alcatel-Lucent OmniVista™ 8770
Network Management System, Release 1.2
and later
• Alcatel-Lucent OmniPCX™ Office Rich
Communication Edition, Release 9.0 and
later
Standards references
(non-exhaustive list)
• RFC 0768 User Datagram Protocol (UDP)
• RFC 0791 Internet Protocol (IP)
• RFC 0793 Transmission Control Protocol
(TCP)
• RFC 0826 Address Resolution Protocol (ARP)
• RFC 1321 MD5 Message-Digest Algorithm
• RFC 2131 Dynamic Host Configuration
Protocol (DHCP)
• RFC 2617 HTTP Authentication: Basic and
Digest Access Authentication
* Contact your local sales representative for information
on the latest feature list and system compatibility.
http://www.alcatel-lucent.com Alcatel, Lucent, Alcatel-Lucent and the Alcatel-Lucent logo are trademarks of
Alcatel-Lucent. All other trademarks are the property of their respective owners. The information presented
is subject to change without notice. Alcatel-Lucent assumes no responsibility for inaccuracies contained herein.
Copyright © 2012 Alcatel-Lucent. All rights reserved. E2012125701 (January)
• RFC 2976 SIP INFO Method
• RFC 3261 SIP: Session Initiation Protocol
• RFC 3262 Reliability of Provisional
Responses in SIP
• RFC 3263 SIP: Locating SIP Servers
• RFC 3264 An Offer/Answer Model with
Session Description Protocol (SDP)
• RFC 3265 SIP-Specific Event Notification
• RFC 3326 The Reason Header Field for
the SIP
• RFC 3515 The SIP Refer Method
• RFC 3611 RTP Control Protocol Extended
Reports (RTCP XR)
• RFC 3842 A Message Summary and
Message Waiting Indication Event Package
for the SIP
• RFC 3891 The SIP “Replaces” Header
• RFC 3892 The SIP Referred-By Mechanism
• RFC 3960 Early Media and Ringing Tone
Generation in the SIP
• RFC 4566 SDP: Session Description
Protocol
• RFC 4733 RTP Pa
Phone only
• Color: Black
• Redial/Mute
• Local interphony
Display
• Comfort handset
• Volume controls
• Mute control
CODECs
Keys and navigation
Audio
• Mute key
Application keys
Navigation
• ‘C’ancel key
¬ Admin settings
¬ Device settings
¬ Call log
¬ Dialing menu
¬ Routing
¬ Local directory
Accessories
Power
support
<= 2.68 W
Connectivity
(8012 DeskPhone)
• DHCP/AVA
• HTTP/HTTPS
Quality of service
• 802.1 P/Q, DSCP
and end-of-call
Security
deployment)
Flooding
and localization
Accessibility
front visibility)
Telephony
• Make/Receive call
• Call transfer
• Call Hold/Resume
• 3-way conference
• Call log for:
¬ Missed calls
¬ Outgoing calls
¬ Incoming calls
• Dial by name
• CLIR/CLID
Contact management
local contacts
and later
later
(TCP)
Protocol (DHCP)
Responses in SIP
the SIP
Reports (RTCP XR)
for the SIP
Protocol
• RFC 4733 RTP Pa
Alca_holic
