H323, "Abbr. No. by pref" change Ipadress for 500+ entries
mihakaufman
Post by mihakaufman »
Hi Guys,
is there a way by scripting or a tool or a command where i can change for 500+ entries the IP-Adress for "Abbreviated No. by prefix".
Everything stays the same, just the IP-Adress has to be changed, and i am not willing to type 500 times the same stupid ipadress.
Please help - thanks in advance.
Miha
Re: H323, "Abbr. No. by pref" change Ipadress for 500+ entri
Use 4760 (4760i) - export/import feature.
Export SD like text file, edit and import back.
Return to “Usefull commands”
