OXO--Open Touch connection
mgsox
Hi everyone I have a problem concerning the interconnection between OmniPCX Office 9.1 and opentouch 1. They are connected using sip trunk. User A is located in OXO and B in open touch. The algorithm used id G711. When A calls B, the communication is ok. When B calls A the set rings ok when they try to answer the communication is cut (on off hook). On the sip trace I get
SIP/2.0 488 Not Acceptable Here
User-Agent: OXO_GW_910/037.001
Reason: Q.850;text="Bearer capability not implemented";cause=65
Warning: 305 172.16.9.11 "No Common Codec"
To: <sip:1605@172.16.9.11;user=phone>;tag=156c519c15a5a4cc7d09114beede8b27
From: "Visitor ." <sip:97976301@172.16.29.3;user=phone>;tag=c38a3dd4cb04685cfec6c898feed4edf
Call-ID: ea8ba72963b17daf14b9765b6b602946@172.16.29.3
CSeq: 322437136 INVITE
Via: SIP/2.0/UDP 172.16.29.3;branch=z9hG4bKea6776f855cb7a64fbdd911c28438b8a
Content-Length: 0
Content-Length: 0
- tot3nkopf
Re: OXO--Open Touch connection
mgsox
thanks for the reply
yes it is !but how do i solve it? both pbx have the same codec. so what is the problem?
- tot3nkopf
framing?mgsox wrote:thanks for the reply
mgsox
the codec is g711 a-law 20ms ( i should have said that before! sorry) the connection was working when oxo was r8. we have upgraded the system few days a go
- tot3nkopf
if you leave default on OXO side what happens?mgsox wrote:the codec is g711 a-law 20ms ( i should have said that before! sorry) the connection was working when oxo was r8. we have upgraded the system few days a go
mgsox
we have the same issue. that is why we only configured one type of code in both sites to see if there was a mismatch. ( a new codec g722 is on the market!)
- tot3nkopf
Check codec pass-through settings on OXO side.mgsox wrote:the codec is g711 a-law 20ms ( i should have said that before! sorry) the connection was working when oxo was r8. we have upgraded the system few days a go
If you dial from an analog or digital set you have the same issue?
I don't believe it... check the negotiation messages and verify codec is the same. Avoid multicoding
Sent from my XPeria Z
mgsox
Case solved!
If I configure the ars of oxo to have default compression, it works fine.
It looks like a bug to me but is a work around!
Thank you all for your help
