ABC-F call fail in one directory and work on another one
IP and Voice over IP
ThiagoNicholas
Post by ThiagoNicholas »
Hi, guys.
I have the problem with ABC-F call in this scenary:
set 1910 (OXE node X) call to SIP service set 474444 (URA) on node Y. The call is OK.
set 1855 (OXE node X) call to SIP service set 474444 (URA) on node Y. The call alert (for caller side) for 5 or 6 times, and them again for more 5 or 6 times, and more one try, and them is released.
Both de sets are 4018 Ip-Touch, on the same node, the same IP domain, the same categories and attributes.
I try to use de same IP for boths sets (alternate), and I try to use both sets on the same IP Desktop SoftPhone (on the same PC). The result is the same, 1910 OK and 1855 only alert (ring).
I delete set 1855 e create again, but didn´t work.
Attached:
Trace T3 OK - set 1910
Trace T3 NOK, only alert (ring) - set 1855
VPN trace OK - set 1910
VPN trace NOK, only alert (ring) - set 1855
Thanks for help.
Re: ABC-F call fail in one directory and work on another one
HI
trace vpn ok show that coedc are g729
and trace vpn nok that one sid is not a g729 compatible
Return to “IP / VoIP”
