having a Problem with an ICS 6.6. No user can login anymore.
WebAdmin Login is possible.
When a I try to connect via the LDAP Admin Tool I get an Error Message like this:
LDAP error: no existing Object!
A restore of a Backup doesn't help.
Even an upgrade to the latestVersion doesn't help.
I checked the TG63 and found : in this case of Problem I have to launche this script file:
Chapter 20.1
./opt/Alcatel-Lucent/Sybase/bin32/sa_config.sh
[root@srvtkotuc /]# ./opt/Alcatel-Lucent/Sybase/bin32/sa_config.sh
iAnywhere Solutions, Inc. One Sybase Drive, Dublin, CA 94568, USA
Copyright (c) 2001-2007, iAnywhere Solutions, Inc. Portions copyright (c)
1988-2007, Sybase, Inc. All rights preserved. All unpublished rights reserved.
dbisql -c "DBN=DIRECTORIES;UID=DBA;PWD=sql" sp_tables@table_owner = "'DIRECTORIES'"
[root@srvtkotuc bin32]# ./dbisql -c "DBN=DIRECTORIES;UID=DBA;PWD=sql" sp_tables@table_owner = "'DIRECTORIES'"
Exception in thread "main" java.lang.ExceptionInInitializerError
at com.ianywhere.errorreporting.DiagnosticInfo.isInstalled(DiagnosticInfo.java:48)
at com.ianywhere.errorreporting.ErrorReportingServiceClient.getErrorReportDirectoryName(ErrorReportingServiceClient.java:208)
at com.ianywhere.errorreporting.ExceptionHandler.writeExceptionFile(ExceptionHandler.java:838)
at com.ianywhere.errorreporting.ExceptionHandler.handleException(ExceptionHandler.java:195)
at sybase.isql.isql.main(isql.java:581)
Caused by: java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159)
at java.awt.Window.<init>(Window.java:318)
at java.awt.Frame.<init>(Frame.java:419)
at java.awt.Frame.<init>(Frame.java:384)
at javax.swing.SwingUtilities$SharedOwnerFrame.<init>(SwingUtilities.java:1666)
at javax.swing.SwingUtilities.getSharedOwnerFrame(SwingUtilities.java:1743)
at javax.swing.JOptionPane.getRootFrame(JOptionPane.java:1624)
at com.sybase.util.SybOptionPane.showOptionDialog(SybOptionPane.java:261)
at com.sybase.util.SybOptionPane.showMessageDialog(SybOptionPane.java:110)
at com.sybase.util.SybOptionPane.showMessageDialog(SybOptionPane.java:104)
at com.sybase.util.DLLLoader.<clinit>(DLLLoader.java:61)
... 5 more
Any idea?
Mozi
no ldap entries anymore
- cavagnaro
Re: no ldap entries anymore
Well as logs indicate:
Do it by GUI no just console.
Seems your LDAP db got corrupted. A FULL backup restore should fix it.
Thanks for the answer.
A full restore doesn't work. Even with the oldest Backup.
When I try to connect to the ldap database with a ldapadmin I get the message
RootDSE content problems.
I tried to delete the database using ldap_db_remove.sh
and created a new one with ldapConf.sh
Is there another possibility to repair the schmatic of the database?
Mozi
Mozi
- cavagnaro
Jummm...you backup also includes LDAP basic objetcs? If so should work if not well...I don't know any other option. Maybe somebody else could answer on this days.
