Fortigate 200A CPU usage 100% ?????
ynkth
Post by ynkth » 03 Sep 2013 04:06
I found CPU usage 100% on system resoruces board
I checked the dialog and saw that
NAT port is exhausted.
Performance statistics
use command: diagnose sys top output below info
And anyone can help me ? Many thanks !
devnull
Re: Fortigate 200A CPU usage 100% ?????
Post by devnull » 19 Sep 2013 08:46
Which Firmware do you use?
There have been multiple bugs in the IPS engine in the past causing lockups of the task..
i would advice you to the fortinet forum (http://support.fortinet.com/forum/default.asp ) where more and more competent people are available.
Return to “Fortigate Security”
