Hi everybody!
ICS server configured and thre is only one application "telephony"
Om the phone thre are 4 apps: collaboration, one number, messaging and telephony
Somebody knows how to delete unused apps (collaboration, one number, messaging) from Ip touch sets?
thenks
Delete unused apps from IP touch set
- cavagnaro
Re: Delete unused apps from IP touch set
Well I do but as you seem to have a hurry and not respect others time and effort then good luck.
Sent from my XPeria Z
cav, are you stressed ;o)
I know it too but as it is already solved I can spend my time for other things
- cavagnaro
Hehe well I was going to answer but then just 6 hours later he posts back like rushing it...didn't like it
For everybody else just to go IPTouch COS and select which Apps you want or not to be shown.
