Red/Critical alarms – TRIPLE EXCEPTION FOR EQUIPMENT 1029
fernando2002
Post by fernando2002 »
Hi guys,
not sure if this is the right place to post this question.
If it is not please point me into right direction.
I am receiving critical error: TRIPLE EXCEPTION FOR EQUIPMENT 1029 from our omnivista 4760 PABX.
Anyone who can tell me what kind of error is this and how I can correct this error please and what will be the effect on our PABX system.
Eliott
Re: Red/Critical alarms – TRIPLE EXCEPTION FOR EQUIPMENT 102
Post by Eliott »
See TC0784. It's first an exception (backtrace 1721) then if its still blocked self defense mechanism starts. If it fails you will get a double check (0248) and if a further attempt to put the device in service again fails to you will get a triple exception (1726)
Eliott
Post by Eliott »
You need to check excvisu to gather more details about the problem. Look for neqt 1029 (tradeq 1029 shows you the directorynumber.
Return to “ON SITE TROUBLES”
