Voice Guide on 'clone db'
toro_dlp
Post by toro_dlp »
I have voice guides (VGs) configured in a system(R 10.0) with local redundancy or 'CS duplication' (main and stdby).
I noted during a contigency that VGs aren´t configured in the secondary CS (stdby).
I do it again a 'mastercopy' by swinst ('clone db') and I put special attention on the opcion '..copy the VGs?' (obviously acepted).
Then I saw it again, but it's the same.
So, in my opinion the problems are two (with 'clone db'):
-Not make the copy of the VG's file;
-Don´t copy the VG configuration (on the 'System' and 'Voice Guide Index').
Somebody have something like that? it´s common?
Eliott
Re: Voice Guide on 'clone db'
Post by Eliott »
It copies just dynamic VG's and customized ones.
Standard VG must be copied by hand from my point of view.
What VG type do you have?
What's the exact problem or error message?
VG must be present on both CPU (/usr7/vg/flash.... or /usr7/vgadpcm/flash...). This is usual case when in duplicated system (or after CPU replacement) installer forgot to download VG file.
toro_dlp
Post by toro_dlp »
Jaja OK, I forget to copy the files. I assume this error (But I can´t find any documentation that talks about this).
And thinking about this, It´s the same with the license file.
The other problem is the configuration of the guides.
When I copy the data base, there is a exclusive item for this. Knowing that their function is not to copy the files then I guess that copies the configuration, but It seems not work.
In my case: (Common Hardware)
CS Main: System/VG Index MG=3 >>> Static VG index=9 >>> asdf.msk
Cs Stdby:System/VG Index MG=3 >>> nothing
Thanks.
Eliott
Post by Eliott »
You have to copy your file onto both CPU before using them in management. Otherwise you will get an MAO error in incvisu and your result as described when reviewing the config on stby.
Sent from my iPhone using Tapatalk 2
toro_dlp
Post by toro_dlp »
ok thanks!
Regards.
Return to “IP”
