How to erase 7210 Config
JFoster1977
Post by JFoster1977 »
I inadvertently configured a 7210 with the wrong config and saved it. I need to erase it and start over. What are the commands to accomplish this? Thanks...
mivens
Re: How to erase 7210 Config
Post by mivens »
Lots of ways of doing it, one way is to find the name of the config file(s) referenced in the output from "show bof". Then rename the files with the command "file move" so the bof references a non-existent file. Then reload.
Or change the bof to point to a non-existent config file, save the bof then reload.
Or reload, interrupt the boot sequence from the console and change the boot parameters to point to a non-existent config file.
lo0
Post by lo0 »
file delete config.cfg
franckorange
Post by franckorange »
Please,
can how can i save my running config in my startup config
Thanks!!
Return to “7210 SAS”
