OXE CPU6 PLAYING TRICKS
gmmbuyisa
Post by gmmbuyisa »
I have CPU 6 which i keep in our lab. With Release 10.1 out, i have used it to perform upgrades without any problem. Now it is getting funny with me, after entering %76.0 and with PC installer opened it keeps timing out instead of loading immediately. I changed the HD, still there was no progress. I tried the same thing with CPU 7-2, things worked perfectly so there is no problem with the software/dhs3mgr/PC or PC installer.
The challenge is i have no spare CPU 6, what would you suggest?
Godfrey
OXE_4400
Re: OXE CPU6 PLAYING TRICKS
Post by OXE_4400 »
What size of HDD ? Some 10GB minimum.
gmmbuyisa
Post by gmmbuyisa »
20GB HDD
Konstantinos.E
Post by Konstantinos.E »
hi
use pc installer from each delivery,turn off firewall and share the directory.
Alca_holic
Eliott
Post by Eliott »
Is already something installed on the CPU6? Can you boot it and Access the CPU via network? You could use 2nd partition installation to proceed with troubleshooting ...
Return to “Software Loading”
