LINK INTER-NODE DONT WORKWHEN I ACTIVATE INTERNAL GATEKEEPER
jpissot
Post by jpissot »
On OXE R10.
There 2 Oxe R10 interconnected by a full IP Link.
There is an intip2 card on the node 1.
I want to activate internal gatekeeper to use H323 phone set.
When I activate, internal gatekeeper on my intip2 card, the calls inter-nodes don't work.
I try to do one trunk to the IP link and one trunk to the H323.
Thank you for your help.
jpissot
Re: LINK INTER-NODE DONT WORKWHEN I ACTIVATE INTERNAL GATEKE
Post by jpissot »
It works withj the parameter " RAS only with H323 term : YES" (IP\IP PARAMETERS)
Return to “IP”
