Hello!
I need to add a digit in the beginning of incoming call CLI, it's possible? Where can I adjust this?
change CLI incoming call
- giovanni.attolini
Giovanni A. Attolini
Re: change CLI incoming call
Use recall prefix in installation numbers if you want to insert numbers for missed calls. but when you answer a call I am not sure you can do it.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
- giovanni.attolini
Ok, but what I need is see the prefix+number on KS/PIMphony, so this field doesn't solve the problem. There is a table called Numbering Modification Table, can it be used? How can I use it?
