Connecting a door buzzer/lock/DTMF system
cbowser814
Post by cbowser814 »
Ok, so this might be pushing the limit here. I've gotten some really great help from you guys so far (vad). What I've got is a call button. I've given it an extension and set up set supervision and attached it to an SLI8-2 board. When I push the button outside I get a dial tone but it doesn't alert the supervising set. When a person pushes the button that I have the supervision set up on it allows for a two way intercom, which is what I want. As far as the wiring goes, the initial signal comes down to a punch-down block. The signal is then split so that it goes to my phone system and also to a relay that is listening for DTMF tones to unlock the door. It almost seems like either I need to be able to have the button autodial the extension or I've gotten something backwards.
Any help will be greatly appreciated.
Re: Connecting a door buzzer/lock/DTMF system
You just need to configure routing at off hook to the phone that must open the door:
-> call button pressed = off hook of the analog extension --> routing at off hook triggered --> phone designated to answer/open door is rang --> predefined key with dtmf digits pressed --> door opens
cbowser814
Sorry I took so long to get back. I finally found the phone COS that I want and I set it to route and off-hook but I don't know how to designate the phone to answer, unless it's just the extension.
Not sure (never tried) but it can also be a hunt group.
