mgr menu "Set Profiles" usage
pilotrus
Post by pilotrus »
It is locate in root mgr menu.
What does this feature mean? Has somebody experience of using it?
I am looking for easy method of configuring and managment of PROGRAMMABLE KEYS.
How can i simplify changing keys configuration of more then 1000 existing users?
OXE IPMG v6.2
knightr1der
Re: mgr menu "Set Profiles" usage
Post by knightr1der »
If you want to create a new user with same keys as another existing user, then use Profile User and create under their. In there you can set the reference extension for which the keys are to be copied from.
If you want to change a key on all 1000 users, export the keys using 4760 to a text file. Open the file with Excel and delete all the keys that you do want to touch. Then just change the keys you do want to and re-import the file. Then go & get a cup of coffee while the import runs :D
pilotrus
Post by pilotrus »
knightr1der wrote:If you want to create a new user with same keys as another existing user, then use Profile User and create under their. In there you can set the reference extension for which the keys are to be copied from.
Yes I know about Profile User and how to use it, but i don`t need to create users.
knightr1der wrote: If you want to change a key on all 1000 users, export the keys using 4760 to a text file. Open the file with Excel and delete all the keys that you do want to touch. Then just change the keys you do want to and re-import the file. Then go & get a cup of coffee while the import runs :D
I have some problems with using 4760 via low bandwith IP channels to remote PBX. Thats why this method does not work always.
agiftel
Post by agiftel »
Hi... I tried to use Profiled Users but Set Supervision' keys are not copied..Where am I wronging???
P.S. I setted in a profile user a Multiline key...
Thank u
knightr1der
set supervision keys are not copied. you have to do them yourself.
agiftel
Post by agiftel »
Ah ok...so I made well :-)
Thank u.
Return to “Users”
