Hi, i need to configure the 802.1x parameters from IP-Touch via telnet. The only config i could find was IP.
I search in the forum and also in the TKB, i try with the help command in the telnet connection but didn't find the way to config.
Config iptouch via telnet
jonvasbar
Re: Config iptouch via telnet
I hope that the attachhed tecnical communication will be of much help you need. On page 98 is described Telnet authorization procedure on OXE.
Best regards
Best regards
alcatellucentryd
I want to change extension number on iptouch 4018 phone like from 3125 to 1106.
- cavagnaro
Then use mgr can't be done on the set. Read basic documents please
Sent from my XPeria Z
byronwak
Hi all,
Is in V6. I find the way to set the paramater with the Idenfifier
N_Ident, is my Identifier that I already get the code.
V_Valor, the value that I want.
TopDoc.Parameters & System.Convert.ToStringN_Ident.SetConvertedValueV_Valor,mm
Best Regards,
FlГЎvio Ruivo
Best Regards,
FlГЎvio Ruivo
