Busy tone on analog extensions
MR_PT1
Post by MR_PT1 »
After call to any analog extension and it has no answer, if I try to call again quickly I receive busy tone.
Only after about 5 seconds I receive the ring tone if I keep trying to call to the analog extension.
Any idea?
sadim
Re: Busy tone on analog extensions
Post by sadim »
Analog clip is active?
Return to “ON SITE TROUBLES”
