6450p10l switch image is carshed,, wht to do ...
mhrahmanpt
6450P10l switch is down and getting console of " ceritfied>kernel> " and not able to get configuration mode.. is it image issue. .how can i reimage from this mode...
devnull
Re: 6450p10l switch image is carshed,, wht to do ...
You could try a USB stick (smaller than 2GB), that is recognized by ALU switches (try it on a workíng switch)
create a file (can be empty) named aossignature in /
create file system structure
/6450/working
/6450/certified
And copy the image files into both (you probably only need "/6450/certified" for that) directorys
This would enable the switch for disaster recovery, so plugin the USB stick an powercycle the switch and watch the console output
/6450/working
/6450/certified
devnull
Just pluing the USB and powercycle the switch.
When observing the Console output you should see something like "disaster recovery in progress" and the switch should copy the files from /6450/certified to the switch.
If that does not help open a SR.
ynkth
Don't do configration the switch?devnull wrote:You could try a USB stick (smaller than 2GB), that is recognized by ALU switches (try it on a workíng switch)
/6450/working
/6450/certified
devnull
No disaster recovery was introduced with support of USB (i think 6.4.3) on 6400/6850 and i think in some maintanace release train of 6.6.1
If the switch can not locate an image it should work with just plugging the USB in..
Why don't you just try, i don't think your switch works atm, so why wait?
ynkth
thanks youur return
I did it again and again and this is my console output
AOS kernel version: 6.6.3.372.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on May 14 2012, 13:15:10.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.1.01.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2012. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
The current date and time is:
Coordinated Universal Time (UTC): SUN DEC 31 00:31:30 2000
Local time: SUN DEC 31 00:31:30 2000 UTC
Starting dynamic software load from '/flash/certified/'...
Unable to load image file 'loadBase.lnk'.
Certified: [Kernel]->
chapman1507
you have to update the switch. This version is buggy. I had the same probelm. I think, its fixed since version 6.6.3 438 R01.
If you have problems to update the switch (can't write on flash), format the flash and make a usb disaster recovery.
mhrahmanpt
since i am very new to this alcatel family.. could you please assist me step by step..how to solve this issue..
jdsm
I don't know if you have already solved your problem, but what you should do is:mhrahmanpt wrote:since i am very new to this alcatel family.. could you please assist me step by step..how to solve this issue..
Step 1)Prepare the an USB Pendisk (2GB or less) to recover your switch. Use the following steps
Step 1.1) Format an USB Pendrive (2GB or less) with FAT16 filesystem in your computer
Step 1.2) Create directories in USB Pen's filesystem
/6450
/6450/working
/6450/certified
Step 1.3) Download the switch firmware archive from Alcatel and extract all files, especially the *.img files, and copy them to /6450/certified directory in USB Pen's filesystem
Step 2) Boot the Switch and wait until reaches the fallback prompt with mentioned earlier, which is "Certified: [Kernel]->"
Step 3) Format the switch's flash executing
Certified: [Kernel]-> sysNewfs "/flash"
Step 4) Insert the USB Pen in the switch's USB port
Step 5) Power cycle the Switch and allow it to automatically copy the firmware from the USB Pendisk.
You can read more information from "OmniSwitch 6250/6450 Switch Management Guide", Chapter 5, in topic "Disaster Recovery Using USB".
Jorge Matias
