is it possible to create GD/GA in VMware
hunggundam
Post by hunggundam »
hi all
i success to create CS R9 in VMware.
it is work.
But i try to create Media Gateway (GD Card) similar as CS in VMware, but not success.
Is it possible to create (GD / GA) in VMware?
Thanks!!! :)
enio.eltz
Re: is it possible to create GD/GA in VMware
Post by enio.eltz »
Yes, it is possible. Vmware Just replaces CS board.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
hunggundam
enio.eltz wrote:Hi
you mean VMware just only replace CS board, GD/GA board can not use it. is ir correct?
enio.eltz
Post by enio.eltz »
Yes, GD/GA must be the specific board. You plug them in a large rack.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
outerman8651
Post by outerman8651 »
hunggundam wrote:hi all
it is work.
Thanks!!! :)
how to create CS R9 in Vmware? appreciate so much...
As Blade or Appliance. With Blade you have also the console output on the screen. With appliance you need a pipe to control console output.
oldboy
Post by oldboy »
A virtual GD board is coming later this year.
oldboy wrote:A virtual GD board is coming later this year.
This is very interesting. Any docs available? On which sw release should this be available?
jasic
Post by jasic »
Should be available in R 11
oldboy
Post by oldboy »
Tot, no docos available as yet but when i get some more info i will be sure to pass it on
Return to “Other”
