Connexion troubles to OXO, error save/restore 20491
Dom
Post by Dom »
Hi everyone,
I could connect to a PBX OXO via the LAN. But I cannot anymore. I get the folowing messages :
File transfert:
Sending file c:\progra~1\pcxtools\omc\r800_24.1\temp\1\OMCrequest_0000 to PBX failed
After pressing OK I get this message:
Save/restore failure with code 20491
I tried to re-install OMC, but it does nothing.
I found questions about the problem, but not answers... If anyone could help, it would be very apreciated.
enio.eltz
Re: Connexion troubles to OXO, error save/restore 20491
Post by enio.eltz »
Release of the OXO and OMC?
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
hakanbayar
Post by hakanbayar »
I'm having the exact same problem for one of our systems. my OMC v.810.22.1a.
Tried logging in from 2 different PC's to branch office IP got this error.
Tried both PC's to connect to Main office, no problem.
Problem occurred after we had powercuts for 1-2day.
barbarabv
Post by barbarabv »
Hi everyone,
I have the same problem, someone has solved it?
I have a windows 7 laptop, OMC v.900 13.1a
Before replacing my hard disk with a SSD onem everything was working; I have already tried to unistall and reinstall OMC software.
Thank you a lot for any suggestion
dimaurod
Post by dimaurod »
I resolved the problem adding a connection rule on the "Windows Defender Firewall", I authorized for all profile the program
%ProgramFiles% (x86)\PCXTools\OMC\R52.0_18.1a\bin\omc.exe
R1988
Post by R1988 »
dimaurod wrote: 19 Apr 2023 02:15 I resolved the problem adding a connection rule on the "Windows Defender Firewall", I authorized for all profile the program
Thank you :D
Return to “MAIN”
