Disabling rlogin, chargen, etc
tcompter
Post by tcompter »
I'm working on configuring an Alcatel 6855-U24X switch. I need to be able to prove to myself (and my boss) that the following services are disabled: rsh, rlogin, rcp, and rdist, echo, chargen, and discard.
I'm reading the Switch Management Guide, The CLI Reference, and the Network Configuration Guide.
The only mention I can find in ANY of those references is in the latter, on page 31-15, in the ACL Manager Chapter. Our application doesn't involve using ACLs at all, so I'm not sure how this would even apply.
What would be best is a 'show' command that would show these services disabled, similar to "show ip service" which shows the enabled status of ftp, http, etc.
Thanks for any insight.
__________
. | homas
benny
Re: Disabling rlogin, chargen, etc
Post by benny »
I hope this is good enough ...
OS6850-48L-Lab-> show tcp ports
  Local Address     Local Port   Remote Address    Remote Port    State
  0.0.0.0                   21   0.0.0.0                     0    LISTEN
  0.0.0.0                   22   0.0.0.0                     0    LISTEN
  0.0.0.0                   23   0.0.0.0                     0    LISTEN
  0.0.0.0                   80   0.0.0.0                     0    LISTEN
  0.0.0.0                  260   0.0.0.0                     0    LISTEN
  0.0.0.0                  261   0.0.0.0                     0    LISTEN
  0.0.0.0                  262   0.0.0.0                     0    LISTEN
  0.0.0.0                  443   0.0.0.0                     0    LISTEN
OS6850-48L-Lab-> show udp ports
  0.0.0.0                    0
  0.0.0.0                   67
  0.0.0.0                   68
  0.0.0.0                  123
  0.0.0.0                  161
  0.0.0.0                  996
  0.0.0.0                 2048
OS6850-48L-Lab-> show ip service
  Name                   Port   Status
  ftp                      21   enabled
  ssh                      22   enabled
  telnet                   23   enabled
  udp-relay                67   enabled
  http                     80   enabled
  network-time            123   enabled
  snmp                    161   enabled
  avlan-telnet            259   enabled
  avlan-http              260   enabled
  avlan-secure-http       261   enabled
  secure-http             443   enabled
  avlan-http-proxy        262   enabled
OS6850-48L-Lab-> no ip service all
  Name                   Port   Status
  ftp                      21   disabled
  ssh                      22   disabled
  telnet                   23   disabled
  udp-relay                67   disabled
  http                     80   disabled
  network-time            123   disabled
  snmp                    161   disabled
  avlan-telnet            259   disabled
  avlan-http              260   disabled
  avlan-secure-http       261   disabled
  secure-http             443   disabled
  avlan-http-proxy        262   disabled
  0.0.0.0                    0
  0.0.0.0                   68
  0.0.0.0                  996
  0.0.0.0                 2048
Benny
tcompter
Post by tcompter »
Thanks! :) That's a step in the right direction. Do I correctly infer that if there are no entries in the "show tcp ports" table, it means that there are no services running?
__________
. | homas
benny
Post by benny »
Yes, your assumption is correct.
Return to “OmniSwitch 6855”
