Problem with analog phones
fervelmart
Post by fervelmart »
Greetings!
I have a problem with analog phones, I can't make calls, neither internal nor external, when picking up the receiver, I get busy tone I get on all devices, digital phones work fine, but when dialing to an extension analog, sent the legend "Not available"
all phones are connected but I can not use
I hope you can help me
greetings
Re: Problem with analog phones
some config command
termstat d mcdu command to see what's state of analog user with the issue
dspstat
fervelmart
thanks for you answer, I'm configuring the Alcatel oxo, the system handling is OMC, ignore how and where to execute the command termstat within the OMC system. the system release is 8
Greetings
i'm sorry but i haven't SEEN that it was an OXO. forgot about commands they are for OXE ;-°
I can say it 's license issue a t 99%
fervelmart
no problem, thanks for trying to help
fervelmart
just to tell them and that this blog will not remain without solution, restore the database and it seems everything is working properly. are grateful for their help.
hanobiwan
Post by hanobiwan »
ceck the Flag "Unlocked, locked" in the OMC Subscriber > Miscellaneous> Lockstate.
Return to “Configuration”
