I told alcatel to remove hotel application from locks cause I am not using it in hotel mode but as company and when I tried to load te new locks the following error was given :
“Do you agree the new software keys (y/n): y
ooo Reading string-file /DHS3bin/oneshot/mtcl/objects.US0 ...
ooo Reading string-file /DHS3bin/oneshot/mtcl/spadmin.dct ...
ooo Reading string-file /DHS3bin/oneshot/mtcl/err2lov.dct ...
No log file to recover
Error : Bad value for package Hotel : AHL on V24 number 1
*** INVALID NEW FILE software.mao : copy not done ***
ERROR: OPS files not copied.”
I tried to load them on a new database and they worked.
So it seems its something in the database.
Any ideas?
I checked the v24 in systems but there is nothing configured and checked also computer link in hotel application menu but there is nothing configured.
Regards#
Wallace
New Software Key loading problem
- tot3nkopf
Re: New Software Key loading problem
Remove from configuration for AHL over v24 link. It looks that it is not covered by the new license. Then load new OPS.Error : Bad value for package Hotel : AHL on V24 number 1
wallacezammit
I think I did that. I went to system>v24> and programmed the v24 ports as none.
Then I also checked in applications>hotel> and removed anything which had to do with v24 ports.
Don't know if there's something else.
- tot3nkopf
Is this a hotel installation or business?
You could try to change the Installation parameter under Applications-->Hotel to company
Also check System-->V24 Port configuration
wallacezammit
This is a business. Under app>hotel> it was always set to company.
But it also had the hotel feature activated in it and since we are upgrading it we are removing the hotel since there is no need for it.
I was told to change the .swk file to software.mao and place it in usr3/mao. Reset the pabx and then upload the locks again.
It worked but it gave some errors. I will check with Actis team regarding this.
Thanks and Regards
Wallace
Thanks and Regards
Wallace
