Busy on Associated set ???
stefanc
Post by stefanc »
Hi all !!!
Have a problem, a customer has a twin with a desktop and a M300, now he wants a Remote ext. as well. So I set the REX no to the asc. set and change Phone Features COS to forward when no answer.
It works, but when next call is done to the mainset , after the timer expires overfl.to.asc. it keeps on ringing, the PBX seems to never try to call the Asc. set. or tell the caller that the asc. set is busy
If I hang up the first call the second is presented on the associtated.
Bug or a feature :)
version OxE on Crystal, 9.1.25a
Re: Busy on Associated set ???
From what is documented the twin set (tandem) cannot be also the associated set.
stefanc
Post by stefanc »
Hi !
Sorry, I don't understand what you mean .....
In the documentation it is stated that the tandem extension number cannot be configured as associated set.
stefanc
Post by stefanc »
Yepp, you're right.
Return to “Users”
