I have a time (approximately 9 seconds) of "transit routes". I guess you should be able to change it but not sure.
For details, at that time, it´s playing the "transit routing tone" (Tono 167).
Time begins with the end of dialing (no matter if they are 3 or 10 digits envoys) and also not matter what type of seizure prefix (with or without overlap, with or without ARS). Also, no matter the type of trunk, at least do the same with analog lines (APA board) or PCM R2 (PRA T2 board).
Thanks.
Time of "transit routing"
- tot3nkopf
Re: Time of "transit routing"
Try to modify timer 136 and see how it goes.
That timer is related to ARS.
And have the same time for direct seize prefix trunk group.
I searched all timers with 8, 9 and 10 seconds, I changed one by one, I found that none is correct (these tests are made on site hurried).
Note: The public provider are different (one for analogue and one for the link R2) and the times are the same.
- tot3nkopf
Did you tried that with ARS seizure? (configure timer 136 as 4)
I have personally been testing (I'm not on site) and I saw that the delay is related only to the PCM R2 trunk group, and not analog lines.
And from what I have understood, that time can not be changed.
Thank you all.
Thank you all.
Hi toro_dlp
Did you find another solution for this case? I have the same one. I am looking for a solution and doing some tests.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
Sorry, had not seen this post.
No, I couldn´t find anything else, about it.
Best regards.
Best regards.
