I installed OXO, release 820.030, pimphony 6.5 IP media, on multiple computers and all of them the sound are very low.
I tested several headset (Plantronics, Microsoft...) and all of them the same problem.
I tested all the windows sound settings, but whom I called, he listened very very low. I called for a analog set.
If I increase the volume in Windows, I listen distorted on analog set.
As the maximum volume that the system supports has been reached, if increase, distorts!
Anyone have this problem?
I need help.
Thanks.
Israel Sousa
pimphony ip media with audio very low
lbanias
Re: pimphony ip media with audio very low
I have exactly the same problem on release 820/026.007. I am curious if Relese 9.x has the same problem, so that I can upgrade the system. The problem is that I don't have R9 licenses for Pimphony to try it.
cganss
i had the same problem. Disable the "echo cancellation" in the Audiosettings of Pimphony.
That was the solution for me and evething work fine.
L_lefante
I am having the same problem. Extremely low volume from Pimphony Multimedia.
OXO is R10.1 and Pimphony 6.8.
I didn´t find echo cancellation configuration in Pimphony (as suggested above), I tried to change it from VoIP parameters in OXO configuration with no positive result.
Have anyone else faced this problem??? Any other recomendation??
Regards.
Regards.
L_lefante
I found where to change Echo cancellation from Pimphony and that solved the problem.
When trying to configure echo cancellation i always get attached error un many computers, anybody knows how to solve it ? It is runtime error when openning audio settings
DrJuanNadie
