Nat issues
alonso.garcia
Nat issues
Post by alonso.garcia »
Hi:
From time to time I'm having this problem,and the router stop the NAT function.
2012 Jul 10 10:41:43: %SWE-4-NAT: not able to snat the packetcoming from src
ip 10.51.1.94 on port: 52303
2012 Jul 10 10:41:44: %SWE-4-NAT: not able to snat the packetcoming from src
ip 10.51.1.175 on port: 50038
2012 Jul 10 10:41:45: %SWE-4-NAT: not able to snat the packetcoming from src
ip 10.51.1.171 on port: 1382
ip 10.51.1.225 on port: 50575
when I give it a reset, all is ok ,but the problem could back in 3 or 4 days
djuntak
Re: Nat issues
Post by djuntak »
I have the same problem and have to reset it so it will be ok again.
Still don't know what to do to solve it.
Does anyone know how to solve this problem?
Re: Nat issues
Do you have the latest fimware installed?
djuntak
Re: Nat issues
Post by djuntak »
This is the show version result:
Alcatel-Lucent Software, version 3.1.0, Build 21
Copyright (c) 2003-2011 by Alcatel-Lucent Inc.
Build on Thu Jul 21 00:27:57 IST 2011
It's the latest firmware version, right?
alonso.garcia
Re: Nat issues
I think is the last version, I have the same.
Specifically in my case I have enable the Sip_alg with incoming call working fine.
Another clue in this issue is when i got the nat issues it doesn't affect at all the Sip_alg, the Sip_alg continue working fine
I think I got a problem with mapping port between NAT and SIP .
Any idea???
bugmenot2
Re: Nat issues
Post by bugmenot2 »
same problem here. Snat stop working after some hours using 3.1.0.
The problem is not present if using:
Alcatel-Lucent Software, Version 3.0.0, Build 99
Built on Mon Aug 1 13:56:52 IST 2011
Flash version - 2.0
Return to “OmniAccess 5510”
