Hi @ll
I need to delete TTS api and rs-language how?
Uninstall TTS From ICS 6.6
luism_ricardo
Re: Uninstall TTS From ICS 6.6
because i try change the language and the system have 3 rpm more. another reason is that local storage answer two operator one femele and male.
hehe...you can have as many languages as you want. The problem does raises when you install same language and different genders.
Well rpm -u is your solution
luism_ricardo
Cav, from run this command? rpm -u (folder home/ root...) because i try run in root and have error.
tks
tks
ermm as you install rpm -ivh rs-api.......etc etc etc the same but instead of -ivh do -u
You can find a lot of info about that on Google searching "uninstall rpm"
