Hello friends, I have a import problem: I´m explaim: I have Audicodes MP114 connected Gateway SIP witch OXO R.810/059.11
Audiocdes calls from the outside of the oxo ISDN disconnected to 40 seconds. AudioCodes internal calls to oxo OK, called external inputs Audiocodes OK ... AudioCodes syslog attached with a call ko.
Thanks you
Activated 21d:10h:37m:40s ( lgr_flow)(1025 ) | | TransactionUserMngr::ReturnDialog - #17
21d:10h:37m:40s ( sip_stack)(1026 ) SIPDialog(#17) changes state from DialogDisconnected to DialogIdle
21d:10h:37m:40s ( lgr_psbrdex)(1027 ) recv <-- OFF_HOOK Ch:1
21d:10h:37m:40s ( lgr_flow)(1028 ) #1:OFF_HOOK_EV
21d:10h:37m:40s ( lgr_flow)(1029 ) | #1:OFF_HOOK_EV
21d:10h:37m:40s ( lgr_psbrdif)(1030 ) UpdateChannelParams, Channel 1
21d:10h:37m:40s ( lgr_psbrdif)(1031 ) #1:ConfigFaxModemChannelParams NSEMode=0, CNGDetMode=0, FAXTranType=1, VxxTranType=2, VoiceVol= 0, DTMFVol=-11, InGain=0, RTPRedDepth=0, ECE=1, SCE=3, ECNlpMode=0, DJBufMinDelay=10, DJBufOptFac=10, Result=1)
21d:10h:37m:40s ( lgr_psbrdif)(1032 ) ActivateDigitMap for channel : 1, MaxDialStringLength = 15, MaxEndDialTimer = 4000,
MaxLongInterDigitTimer = 8000, MaxStartTimer = 16000, DigitMap = [0-9*#ABCD][0-9ABCD].T, DialPlanIndex = -1
21d:10h:37m:40s ( lgr_flow)(1033 ) #-100: StartDigitMapDetection with params:
<Pattern=[0-9*#ABCD][0-9ABCD].T>
<MaxStartTimer=16000>
<SendEachDigit=1>
<UseEndDialKey=0>
<MaxLongInterDigitTimer=8000>
<MaxEndDialTimer=4000>
<MaxDialStringLength=15>
<MaxShortInterDigitTimer=2000>
<MinInterDigitLen=-2>
<MinDigitLen=-2>
<EndDialWithHashMark=0>
21d:10h:37m:40s (lgr_digitmap_mngr)(1034 ) #1:Activate DigitMapMngr pattern:[0-9*#ABCD][0-9ABCD].T, Max Length is: 15, DialPlanIndex: -1
21d:10h:37m:40s ( lgr_psbrdif)(1035 ) #1:PSOSBoardInterface::StopPlayTone- Called
21d:10h:37m:40s ( lgr_psbrdif)(1036 ) #1:PSOSBoardInterface::PlayTone - Called Tone=STUTTER_DIAL_TONE Direction=PLAY_TONE_2_TEL
21d:10h:37m:43s ( lgr_psbrdex)(1037 ) recv <-- DIGIT(0) Ch:1 OnTime:0 InterTime:139030 Direction:0 System:1
21d:10h:37m:43s ( lgr_flow)(1038 ) #1:DIGIT_EV
21d:10h:37m:43s ( lgr_flow)(1039 ) | #1:DIGIT_EV
21d:10h:37m:43s ( lgr_psbrdif)(1040 ) #1:PSOSBoardInterface::StopPlayTone- Called
21d:10h:37m:43s ( lgr_psbrdex)(1041 ) recv <-- DIGIT(0) Ch:1 OnTime:70 InterTime:139030 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1042 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1043 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1044 ) recv <-- DIGIT(6) Ch:1 OnTime:0 InterTime:80 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1045 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1046 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1047 ) recv <-- DIGIT(6) Ch:1 OnTime:90 InterTime:80 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1048 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1049 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1050 ) recv <-- DIGIT(2) Ch:1 OnTime:0 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1051 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1052 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1053 ) recv <-- DIGIT(2) Ch:1 OnTime:80 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1054 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1055 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1056 ) recv <-- DIGIT(6) Ch:1 OnTime:0 InterTime:80 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1057 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1058 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1059 ) recv <-- DIGIT(6) Ch:1 OnTime:90 InterTime:80 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1060 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1061 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1062 ) recv <-- DIGIT(1) Ch:1 OnTime:0 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1063 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1064 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1065 ) recv <-- DIGIT(1) Ch:1 OnTime:80 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1066 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1067 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1068 ) recv <-- DIGIT(5) Ch:1 OnTime:0 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1069 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1070 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1071 ) recv <-- DIGIT(5) Ch:1 OnTime:80 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1072 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1073 ) | #1:DIGIT_EV
21d:10h:37m:44s ( lgr_psbrdex)(1074 ) recv <-- DIGIT(2) Ch:1 OnTime:0 InterTime:90 Direction:0 System:1
21d:10h:37m:44s ( lgr_flow)(1075 ) #1:DIGIT_EV
21d:10h:37m:44s ( lgr_flow)(1076 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1077 ) recv <-- DIGIT(2) Ch:1 OnTime:80 InterTime:90 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1078 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1079 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1080 ) recv <-- DIGIT(0) Ch:1 OnTime:0 InterTime:80 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1081 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1082 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1083 ) recv <-- DIGIT(0) Ch:1 OnTime:90 InterTime:80 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1084 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1085 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1086 ) recv <-- DIGIT(7) Ch:1 OnTime:0 InterTime:90 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1087 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1088 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1089 ) recv <-- DIGIT(7) Ch:1 OnTime:80 InterTime:90 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1090 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1091 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1092 ) recv <-- DIGIT(6) Ch:1 OnTime:0 InterTime:80 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1093 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1094 ) | #1:DIGIT_EV
21d:10h:37m:45s ( lgr_psbrdex)(1095 ) recv <-- DIGIT(6) Ch:1 OnTime:90 InterTime:80 Direction:0 System:1
21d:10h:37m:45s ( lgr_flow)(1096 ) #1:DIGIT_EV
21d:10h:37m:45s ( lgr_flow)(1097 ) | #1:DIGIT_EV
21d:10h:37m:49s ( lgr_psbrdex)(1098 ) recv <-- EV_DIALED_STRING Ch:1 Str:0626152076 MapNum:0 CM:FM Match:1 EI:
21d:10h:37m:49s ( lgr_flow)(1099 ) #1:DIALED_STRING_EV
21d:10h:37m:49s ( lgr_flow)(1100 ) | #1:DIALED_STRING_EV
21d:10h:37m:49s (lgr_digitmap_mngr)(1101 ) DigitMapMngr::HandleDialStringEv Match = 1, MatchNum = 0 STR = 0626152076
21d:10h:37m:49s ( lgr_call)(1102 ) Call Allocated ResourceID: 2
21d:10h:37m:49s ( lgr_flow)(1103 ) | #1:NEW_CALL_EV (send) : (UnKnown)
21d:10h:37m:49s ( lgr_flow)(1104 ) | | #2:NEW_CALL_EV:(UnKnown)
21d:10h:37m:49s ( lgr_stk_mngr)(1105 ) Resource StackSession <#2> Allocated
21d:10h:37m:49s ( lgr_flow)(1106 ) | | #2:Call changing states from:IdleState to:NewCallState_Tel2IP
21d:10h:37m:49s ( lgr_flow)(1107 ) | | | #2:NEW_CALL_EV(Unknown)
21d:10h:37m:49s ( lgr_call)(1108 ) | | #2GetNextUI:GlobalUI=1934269675, mACAddrLsb=2977474
21d:10h:37m:49s ( lgr_call)(1109 ) | | #2GetNextUI:GlobalUI=1934269676
21d:10h:37m:49s ( lgr_flow)(1110 ) | (to 0626152076)
21d:10h:37m:49s ( lgr_flow)(1111 ) | #1:SETUP_EV (send) : (UnKnown)
21d:10h:37m:49s ( lgr_flow)(1112 ) | | #2:SETUP (TO:0626152076, FROM:41):(UnKnown)
21d:10h:37m:49s ( lgr_call)(1113 ) new call from EndPoint
21d:10h:37m:49s ( lgr_flow)(1114 ) | | #2:Call changing states from:NewCallState_Tel2IP to:InitiatedState_Tel2IP
21d:10h:37m:49s ( lgr_flow)(1115 ) | | | #2:SETUP_EV(Unknown)
21d:10h:37m:49s ( lgr_call)(1116 ) Call::GetStartIndex() return -1
21d:10h:37m:49s ( lgr_stack)(1117 ) FindIpDestination: rmRc:0 (OK) SrcIpGroup:-1 IpconnHndl:-1 DstPrefix:0626152076 DstIp:
21d:10h:37m:49s ( lgr_stack)(1118 ) RoutingInstance (#2) RouteToProxyIfExists: find route to proxy DestIPGroup 0
21d:10h:37m:49s ( lgr_stk_ses)(1119 ) <SESSION #2> UpdateAfterDecidingRouting: IpProfileId (0), ChargeCode (255), NewIndex (-100)
21d:10h:37m:49s ( lgr_call)(1120 ) Call::SetCoderListForCall #2 Found 2 Common Coders For Call
21d:10h:37m:49s ( lgr_call)(1121 ) <Call #2> Coder g711Alaw64k20 : 20
21d:10h:37m:49s ( lgr_call)(1122 ) <Call #2> Coder g711Ulaw64k20 : 20
21d:10h:37m:49s ( lgr_profiling)(1123 ) <Call 2> Profiled<Tel=0,Ip=0>: JBMinDel=10 JBOptF=10 EEarlyM=1 FaxTM=1 IPDS=46 IsFaxU=1 PI2IP=-1 SigIPDF=40 CNGMode=0 DTMFUsed=0 NSEMode=0 PlayRBTone2IP=0 RBUdpPort=0 RTPRD=0 SCE=0 VxxTT=2 Dst2Rdrt=0 DTMFVol=20 ECE=1 ECurDis=0 EDigDel=0 ERevP=0 FHPer=700 InG=32 MWIA=0 MWID=0 VVol=32 ReorderTime=255 DIDWink=0 2StageDial=1 DiscOnBusyT=1 DiscOnBrok=1 DPInd=255 AGC=0 NLP=0
21d:10h:37m:49s ( lgr_stk_ses)(1124 ) DecideRoutingSetup DestIpGroupId:0
21d:10h:37m:49s ( sip_stack)(1125 ) new AcSIPCallAPI created - #2
21d:10h:37m:49s ( sip_stack)(1126 ) New SIPMessage created - #20
21d:10h:37m:49s ( lgr_flow)(1127 ) EndPoint::MediaResourceList::AllocateMediaIpPortsByMediaRealmID Perform NEW allocation of Media ports for RealmIndex(0) port(6010) current allocations are:(1)
21d:10h:37m:49s ( lgr_flow)(1128 ) gwGroup::GetSIPGatewayName GroupName of group 0 is not defined. Use the default.
21d:10h:37m:49s ( lgr_flow)(1129 ) | | new GetNewSIPCall created - #5
21d:10h:37m:49s ( sip_stack)(1130 ) SIPSDPSession#2 - Changing state from SIP_MEDIA_IDLE to SIP_MEDIA_OFFERING
21d:10h:37m:49s ( lgr_flow)(1131 ) | |(SIPTU#5)SETUP_REQ State:Idle()
21d:10h:37m:49s ( sip_stack)(1132 ) SIPCall(#5) changes state from Idle to Inviting
21d:10h:37m:49s ( lgr_flow)(1133 ) ---- Outgoing SIP Message to 192.168.1.246:5060 from SIPInterface #0 ----
21d:10h:37m:49s INVITE sip:0626152076@oxo;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.2.200;branch=z9hG4bKac78317017
Max-Forwards: 70
To: <sip:0626152076@oxo;user=phone>
Call-ID: 783093032112000103749@192.168.2.200
CSeq: 1 INVITE
Contact: <sip:41@192.168.2.200:5060>
Supported: em,100rel,timer,replaces,path,early-session,resource-priority,sdp-anat
Allow: REGISTER,OPTIONS,INVITE,ACK,CANCEL,BYE,NOTIFY,PRACK,REFER,INFO,SUBSCRIBE,UPDATE
User-Agent: Audiocodes-Sip-Gateway-MP-114 FXS/v.6.00A.047.003
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 255
v=0
o=AudiocodesGW 78300854 78300734 IN IP4 192.168.2.200
s=Phone-Call
c=IN IP4 192.168.2.200
t=0 0
m=audio 6010 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
21d:10h:37m:49s ( sip_stack)(1135 )
UdpRtxMngr::Transmit 1 INVITE Rtx Left: 6 Dest: 192.168.1.246:5060 CallID: (783093032112000103749@192.168.2.200)
21d:10h:37m:49s ( sip_stack)(1136 ) Resource SIPMessage deleted - #20
21d:10h:37m:49s ( sip_stack)(1137 ) New SIPMessage created - #19
21d:10h:37m:49s ( lgr_flow)(1138 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:37m:49s SIP/2.0 100 Trying
CSeq: 1 INVITE
Content-Length: 0
21d:10h:37m:49s ( sip_stack)(1140 ) UdpRtxMngr::Remove 1 INVITE
21d:10h:37m:49s ( lgr_flow)(1141 ) | |(SIPTU#5)100 State:Inviting(783093032112000103749@192.168.2.200)
21d:10h:37m:49s ( sip_stack)(1142 ) SIPCall(#5) changes state from Inviting to Proceeding
21d:10h:37m:49s ( sip_stack)(1143 ) Resource SIPMessage deleted - #19
21d:10h:37m:49s ( lgr_flow)(1144 ) | | | #2:SIP_TRYING_EV(783093032112000103749@192.168.2.200)
21d:10h:37m:49s ( lgr_stk_ses)(1145 ) <SESSION #2> SendToCall - event: PROCEEDING_EV m_Call#2
21d:10h:37m:49s ( lgr_flow)(1146 ) | | #2:PROCEEDING_EV:(783093032112000103749@192.168.2.200)
21d:10h:37m:49s ( lgr_flow)(1147 ) | #1:PROCEEDING_EV : (783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( sip_stack)(1148 ) New SIPMessage created - #17
21d:10h:37m:50s ( lgr_flow)(1149 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:37m:50s SIP/2.0 183 Session Progress
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE
Contact: <sip:0626152076@192.168.1.246;user=phone>
Require: 100rel
Supported: from-change
User-Agent: OXO_GW_800/052.002
P-Asserted-Identity: <sip:0626152076@192.168.1.246;user=phone>
To: <sip:0626152076@oxo;user=phone>;tag=2ccc1db66146ee6d4060a1399b7b1620
CSeq: 1 INVITE
RSeq: 2147391408
Content-Length: 209
v=0
o=default 1338394501 1338394501 IN IP4 192.168.1.246
s=Phone-Call
c=IN IP4 192.168.1.246
t=0 0
m=audio 32000 RTP/AVP 8 101
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:37m:50s ( lgr_flow)(1151 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_flow)(1152 ) | | | #2:SIP_ALERT_EV(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( sip_stack)(1153 ) New SIPMessage created - #18
21d:10h:37m:50s ( lgr_stk_ses)(1154 ) <SESSION #2> SendToCall - event: PROGRESS_INDICATOR_EV m_Call#2
21d:10h:37m:50s ( lgr_flow)(1155 ) | | #2:PROGRESS_INDICATOR_EV(PI=8)(PC=-1):(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_stk_ses)(1156 ) <SESSION #2> SendToCall - event: PROGRESS_EV m_Call#2
21d:10h:37m:50s ( lgr_flow)(1157 ) | | #2:PROGRESS_EV:(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_flow)(1158 ) | #1:PROGRESS_EV : (783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( sip_stack)(1159 ) SIPSDPSession#2 - Changing state from SIP_MEDIA_OFFERING to SIP_MEDIA_COMPLETED
21d:10h:37m:50s ( lgr_stk_ses)(1160 ) DtmfCapNegotiationAlgorithm :: TxDtmfMethod = DTMF_RFC2833_SUPPORTED
21d:10h:37m:50s ( lgr_stk_ses)(1161 ) DtmfCapNegotiationAlgorithm :: TxRtpRfc2833Payload = 101
21d:10h:37m:50s ( lgr_stk_ses)(1162 ) <SESSION #2> SendToCall - event: DTMF_CONTROL_EV m_Call#2
21d:10h:37m:50s ( lgr_flow)(1163 ) | | #2:DTMF_CONTROL_EV:(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_stk_ses)(1164 ) <SESSION #2> SendToCall - event: OPEN_LOGICAL_CHANNEL_ACK_EV m_Call#2
21d:10h:37m:50s ( lgr_flow)(1165 ) | | #2:OPEN_LOGICAL_CHANNEL_ACK_EV:(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_flow)(1166 ) | #1:OPEN_LOGICAL_CHANNEL_ACK_EV : (783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_flow)(1167 ) | #1:OPEN_VOICE (IP:192.168.1.246, RTP:32000, RTCP:0, VoiceCoder:g711Alaw64k20, VbdCoder: InvalidCoder255, Dtmf:gwRFC2833RalayDTMF,Rx payload:101,Tx payload:101 ,RTPmode:1, FaxTransportType: 1, AVoIPMediaType: gwMediaTypeAudioOnly, T38Version:N/A)
21d:10h:37m:50s ( lgr_psbrdif)(1168 ) activate channel local rtp port:6010, port=32000, BChannel:1, local ip:192.168.2.200, ip=192.168.1.246 (Voice:1,Vbd:0,T38:0,Video:0)
21d:10h:37m:50s ( lgr_psbrdif)(1169 ) #1:ActivateChannel: Socks=17 CID=1 Trunk:-1 BChannel:1 RemoteIP=192.168.1.246 RemotePort=32000 RemoteT38IP= RemoteT38Port=0 RemoteRTCPIP= RemoteRTCPPort=0 FaxModemDet=NO_FAX_MODEM_DETECTED
21d:10h:37m:50s ( lgr_psbrdif)(1170 ) Open channel: IsVoiceOn: 1, IsT38On: 0, IsVbdOn: 0, IsVideoOn: 0
21d:10h:37m:50s ( lgr_psbrdif)(1171 ) #1:OpenChannel:on Trunk -1 BChannel:1 CID=1 with VoiceCoder: g711Alaw64k20 VbdCoder: InvalidCoder255 DetectorSide: 0 FaxModemDet NO_FAX_MODEM_DETECTED
21d:10h:37m:50s ( lgr_psbrdif)(1172 ) #1:OpenChannel VoiceVolume= 0, DTMFVolume = -11, InputGain = 0, RTPRedundancyDepth = 0 FlashHookPeriod = 700 AgcCmd = 0x13180000
21d:10h:37m:50s ( lgr_psbrdif)(1173 ) RFC2833RTPPayloadType: Rx=101 Tx=101
21d:10h:37m:50s ( lgr_psbrdif)(1174 ) OpenChannel, CoderType = 0, Interval = 3, M = 1
21d:10h:37m:50s ( lgr_psbrdif)(1175 ) #1:FAXTransportType = 1
21d:10h:37m:50s ( lgr_psbrdif)(1176 ) #1:ConfigFaxModemChannelParams NSEMode=0, CNGDetMode=0, FAXTranType=1, VxxTranType=2, VoiceVol= 0, DTMFVol=-11, InGain=0, RTPRedDepth=0, ECE=1, SCE=0, ECNlpMode=0, DJBufMinDelay=10, DJBufOptFac=10, Result=1)
21d:10h:37m:50s ( lgr_psbrdif)(1177 ) Detectors: Amd:On=0,Diretion=0, Ans:On=0,Direction=0 En:On=0,Direction=0 Board IBScmd:0xa1
21d:10h:37m:50s ( lgr_psbrdif)(1178 ) #1:Channel will be open WITH DSP
21d:10h:37m:50s ( lgr_psbrdex)(1179 ) PCIIFChangeChannelParams failed RTP_Interval Coder
21d:10h:37m:50s ( lgr_psbrdif)(1180 ) Setting ActivateRTP_RTCPCmd.Cmd.IpTosFieldInUdpPacket to 184
21d:10h:37m:50s ( lgr_psbrdif)(1181 ) #1:ActivateChannel:RtpPayload: 8
21d:10h:37m:50s ( lgr_flow)(1182 ) | |(SIPTU#5)PRACK_REQ State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:37m:50s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
[Code:3700e] [CID:1]
21d:10h:37m:50s ( lgr_flow)(1183 ) ---- Outgoing SIP Message to 192.168.1.246:5060 from SIPInterface #0 ----
21d:10h:37m:50s PRACK sip:0626152076@192.168.1.246;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.2.200;branch=z9hG4bKac80085179
Max-Forwards: 70
CSeq: 2 PRACK
Supported: em,timer,replaces,path,early-session,resource-priority
RAck: 2147391408 1 INVITE
Content-Length: 0
21d:10h:37m:50s ( sip_stack)(1185 )
UdpRtxMngr::Transmit 2 PRACK Rtx Left: 6 Dest: 192.168.1.246:5060 CallID: (783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( sip_stack)(1186 ) Resource SIPMessage deleted - #18
21d:10h:37m:50s ( sip_stack)(1187 ) Resource SIPMessage deleted - #17
21d:10h:37m:50s IP:2 [Code:5004] [CID:1]
21d:10h:37m:50s ( sip_stack)(1188 ) New SIPMessage created - #15
21d:10h:37m:50s ( lgr_flow)(1189 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:37m:50s SIP/2.0 200 OK
Supported: 100rel
CSeq: 2 PRACK
Content-Length: 0
21d:10h:37m:50s ( sip_stack)(1191 ) UdpRtxMngr::Remove 2 PRACK
21d:10h:37m:50s ( lgr_flow)(1192 ) | |(SIPTU#5)200 OK State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( lgr_flow)(1193 ) | | | #2:SIP_PRACK_RESPONSE_EV(783093032112000103749@192.168.2.200)
21d:10h:37m:50s ( sip_stack)(1194 ) Resource SIPMessage deleted - #15
21d:10h:37m:51s IP:14 [Code:5004] [CID:1]
21d:10h:37m:55s ( sip_stack)(1195 ) New SIPMessage created - #16
21d:10h:37m:55s ( lgr_flow)(1196 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:37m:55s SIP/2.0 183 Session Progress
Require: 100rel
CSeq: 1 INVITE
RSeq: 2147391409
Content-Length: 209
v=0
s=Phone-Call
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:37m:55s ( lgr_flow)(1198 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:37m:55s ( sip_stack)(1199 ) ?? [WARNING] Handle18XResponse, Got 18x while prack is in process
21d:10h:37m:55s ( sip_stack)(1200 ) Resource SIPMessage deleted - #16
21d:10h:37m:56s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:37m:56s ( sip_stack)(1201 ) New SIPMessage created - #13
21d:10h:37m:56s ( lgr_flow)(1202 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:37m:56s SIP/2.0 183 Session Progress
Require: 100rel
CSeq: 1 INVITE
RSeq: 2147391409
Content-Length: 209
v=0
s=Phone-Call
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:37m:56s ( lgr_flow)(1204 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:37m:56s ( sip_stack)(1205 ) ?? [WARNING] Handle18XResponse, Got 18x while prack is in process
21d:10h:37m:56s ( sip_stack)(1206 ) Resource SIPMessage deleted - #13
21d:10h:37m:56s IP:4 [Code:5004] [CID:1]
21d:10h:37m:57s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:37m:58s IP:2 [Code:5004] [CID:1]
21d:10h:37m:59s ( sip_stack)(1207 ) New SIPMessage created - #12
21d:10h:37m:59s ( lgr_flow)(1208 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:37m:59s SIP/2.0 183 Session Progress
Require: 100rel
CSeq: 1 INVITE
RSeq: 2147391409
Content-Length: 209
v=0
s=Phone-Call
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:37m:59s [Src=192.168.1.246/32001 Dst=6011 PType=6] ErrMgs=7 Invalid RTCP packet SSRC: Expected = 0x541bac5d Received = 0xf683c89
21d:10h:37m:59s ( lgr_flow)(1210 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:37m:59s ( sip_stack)(1211 ) ?? [WARNING] Handle18XResponse, Got 18x while prack is in process
21d:10h:37m:59s ( sip_stack)(1212 ) Resource SIPMessage deleted - #12
21d:10h:37m:59s IR:1 [Code:5004] [CID:1]
21d:10h:37m:59s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:0s IP:1 [Code:5004] [CID:1]
21d:10h:38m:1s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:1s IP:4 [Code:5004] [CID:1]
21d:10h:38m:3s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:4s IP:1 [Code:5004] [CID:1]
21d:10h:38m:4s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:4s ( sip_stack)(1213 ) New SIPMessage created - #14
21d:10h:38m:4s ( lgr_flow)(1214 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:38m:4s SIP/2.0 183 Session Progress
Require: 100rel
CSeq: 1 INVITE
RSeq: 2147391409
Content-Length: 209
v=0
s=Phone-Call
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:38m:4s ( lgr_flow)(1216 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:38m:4s ( sip_stack)(1217 ) ?? [WARNING] Handle18XResponse, Got 18x while prack is in process
21d:10h:38m:4s ( sip_stack)(1218 ) Resource SIPMessage deleted - #14
21d:10h:38m:5s IP:2 [Code:5004] [CID:1]
21d:10h:38m:6s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:7s IP:4 [Code:5004] [CID:1]
21d:10h:38m:7s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:8s IP:7 [Code:5004] [CID:1]
21d:10h:38m:8s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:9s IP:10 [Code:5004] [CID:1]
21d:10h:38m:9s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:9s [Src=192.168.1.246/32001 Dst=6011 PType=6] ErrMgs=7 Invalid RTCP packet SSRC: Expected = 0x541bac5d Received = 0xf683c89
21d:10h:38m:10s IR:1 IP:9 [Code:5004] [CID:1]
21d:10h:38m:10s [Src=192.168.1.246/32000 Dst=6010 PType=6] ErrMgs=15 Receive SID packet without Payload Type 13
21d:10h:38m:11s IP:1 [Code:5004] [CID:1]
21d:10h:38m:16s ( sip_stack)(1219 ) New SIPMessage created - #10
21d:10h:38m:16s ( lgr_flow)(1220 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:38m:16s SIP/2.0 183 Session Progress
Require: 100rel
CSeq: 1 INVITE
RSeq: 2147391409
Content-Length: 209
v=0
s=Phone-Call
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:38m:16s ( lgr_flow)(1222 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:38m:16s ( sip_stack)(1223 ) ?? [WARNING] Handle18XResponse, Got 18x while prack is in process
21d:10h:38m:16s ( sip_stack)(1224 ) Resource SIPMessage deleted - #10
21d:10h:38m:19s [Src=192.168.1.246/32001 Dst=6011 PType=6] ErrMgs=7 Invalid RTCP packet SSRC: Expected = 0x541bac5d Received = 0xf683c89
21d:10h:38m:20s IR:1 [Code:5004] [CID:1]
21d:10h:38m:30s [Src=192.168.1.246/32001 Dst=6011 PType=6] ErrMgs=7 Invalid RTCP packet SSRC: Expected = 0x541bac5d Received = 0xf683c89
21d:10h:38m:30s IR:1 [Code:5004] [CID:1]
21d:10h:38m:38s ( sip_stack)(1225 ) New SIPMessage created - #8
21d:10h:38m:38s ( lgr_flow)(1226 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:38m:38s SIP/2.0 183 Session Progress
Require: 100rel
CSeq: 1 INVITE
RSeq: 2147391409
Content-Length: 209
v=0
s=Phone-Call
t=0 0
a=sendrecv
a=fmtp:101 0-15
a=ptime:20
21d:10h:38m:38s ( lgr_flow)(1228 ) | |(SIPTU#5)183 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:38m:38s ( sip_stack)(1229 ) ?? [WARNING] Handle18XResponse, Got 18x while prack is in process
21d:10h:38m:38s ( sip_stack)(1230 ) Resource SIPMessage deleted - #8
21d:10h:38m:39s ( sip_stack)(1231 ) New SIPMessage created - #9
21d:10h:38m:39s ( lgr_flow)(1232 ) ---- Incoming SIP Message from 192.168.1.246:5060 to SIPInterface #0 ----
21d:10h:38m:39s SIP/2.0 504 Gateway Time-out
CSeq: 1 INVITE
Content-Length: 0
21d:10h:38m:39s ( lgr_flow)(1234 ) | |(SIPTU#5)504 State:Proceeding(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( sip_stack)(1235 ) New SIPMessage created - #11
21d:10h:38m:39s ( lgr_flow)(1236 ) ---- Outgoing SIP Message to 192.168.1.246:5060 from SIPInterface #0 ----
21d:10h:38m:39s ACK sip:0626152076@oxo;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
21d:10h:38m:39s ( sip_stack)(1238 ) Resource SIPMessage deleted - #11
21d:10h:38m:39s ( sip_stack)(1239 ) SIPCall(#5) changes state from Proceeding to Disconnected
21d:10h:38m:39s ( lgr_flow)(1240 ) | | | #2:SIP_DISCONNECT_EV(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( lgr_stk_ses)(1241 ) <SESSION #2> SendToCall - event: RELEASE_EV m_Call#2
21d:10h:38m:39s ( lgr_flow)(1242 ) | | #2:RELEASE_EV:(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( lgr_flow)(1243 ) | | #2:Call changing states from:InitiatedState_Tel2IP to:DisconnectingState
21d:10h:38m:39s |CALL_END |1 |0 |-1 |1 |0 |0 |FXS |LCL |192.168.2.200 |192.168.1.246 |0 |0 |41 |41 |0 |0 |0626152076 |0626152076 |0 |g711Alaw64k |20 |192.168.1.246 |32000|RMT |GWAPP_RECOVERY_ON_TIMER_EXPIRY |0 |1802 |2484 |0 |-1 |783093032112000103749@192.168.2.200 | | | |0 |64 |245764955 |1411099741 |-1 |0 |0 | |0 | | | | |0 |192.168.2.200 |6010
21d:10h:38m:39s ( lgr_flow)(1245 ) | | #2:RELEASE_ACK_EV:(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( lgr_flow)(1246 ) EndPoint::MediaResourceList::FreeMediaIpPorts Perform dellocation of Media ports for RealmIndex(0) port(6010) current allocations are:(0)
21d:10h:38m:39s ( lgr_flow)(1247 ) | #1:RELEASE_EV GWAPP_RECOVERY_ON_TIMER_EXPIRY : (783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( lgr_psbrdif)(1248 ) #1:cpDigitMapHndlr_Stop - Stoped (0)
21d:10h:38m:39s ( lgr_psbrdif)(1249 ) #1:CloseChannel: ChannelNum=1
21d:10h:38m:39s ( lgr_psbrdif)(1250 ) Open channel: IsVoiceOn: 1, IsT38On: 0, IsVbdOn: 0, IsVideoOn: 0
21d:10h:38m:39s ( lgr_psbrdif)(1251 ) #1:OpenChannel:on Trunk -1 BChannel:1 CID=1 with VoiceCoder: g723130 VbdCoder: InvalidCoder255 DetectorSide: 0 FaxModemDet NO_FAX_MODEM_DETECTED
21d:10h:38m:39s ( lgr_psbrdif)(1252 ) #1:OpenChannel VoiceVolume= 0, DTMFVolume = -11, InputGain = 0, RTPRedundancyDepth = 0 FlashHookPeriod = 700 AgcCmd = 0x13180000
21d:10h:38m:39s ( lgr_psbrdif)(1253 ) RFC2833RTPPayloadType: Rx=101 Tx=101
21d:10h:38m:39s ( lgr_psbrdif)(1254 ) OpenChannel, CoderType = 16, Interval = 0, M = 1
21d:10h:38m:39s ( lgr_psbrdif)(1255 ) #1:FAXTransportType = 1
21d:10h:38m:39s ( lgr_psbrdif)(1256 ) #1:ConfigFaxModemChannelParams NSEMode=0, CNGDetMode=0, FAXTranType=1, VxxTranType=2, VoiceVol= 0, DTMFVol=-11, InGain=0, RTPRedDepth=0, ECE=1, SCE=-1, ECNlpMode=0, DJBufMinDelay=10, DJBufOptFac=10, Result=1)
21d:10h:38m:39s ( lgr_psbrdif)(1257 ) Detectors: Amd:On=0,Diretion=0, Ans:On=0,Direction=0 En:On=0,Direction=0 Board IBScmd:0xa1
21d:10h:38m:39s ( lgr_psbrdif)(1258 ) #1:Channel will be open WITH DSP
21d:10h:38m:39s Invalid Tone Type (7). Channel ID:1 [Code:500c] [CID:1]
21d:10h:38m:39s ( lgr_psbrdif)(1259 ) #1:PSOSBoardInterface::PlayTone - Called Tone=REORDER_TONE Direction=PLAY_TONE_2_TEL
21d:10h:38m:39s ( lgr_psbrdif)(1260 ) !! [ERROR] #1:failed to play tone
21d:10h:38m:39s ( lgr_flow)(1261 ) | #1:RELEASE_ACK_EV (send) : (783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( lgr_flow)(1262 ) | | #2:RELEASE_ACK_EV:(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( lgr_flow)(1263 ) | | | #2:RELEASE_ACK_EV(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( sip_stack)(1264 ) New SIPMessage created - #7
21d:10h:38m:39s ( lgr_flow)(1265 ) | |(SIPTU#5)DISCONNECT_RESPONSE State:Disconnected(783093032112000103749@192.168.2.200)
21d:10h:38m:39s ( sip_stack)(1266 ) AcSIPStackAPI::FreeCallAPI - #2
21d:10h:38m:39s ( sip_stack)(1267 ) Setting ApplicationCall of AcSIPCall 31691112 to NULL
21d:10h:38m:39s ( lgr_stk_mngr)(1268 ) Resource StackSession <#2> Deleted
21d:10h:38m:39s ( sip_stack)(1269 ) Resource SIPMessage deleted - #7
21d:10h:38m:39s ( lgr_call)(1270 ) Call Returned to Pool ResourceID: 2
21d:10h:38m:39s ( lgr_call)(1271 ) delete GW call current active is: 1
Audiocodes MP114 call disconnected 40 seconds
Re: Audiocodes MP114 call disconnected 40 seconds
May be - IP/ IP parameters - Round Trip Delay Request=No?
alarcos
You can be friend ... I updated OXO R810/056.001 and I have the problem. I also tested with other Audiocodes MP112 and similarly ...
excuse me - this is for OXE. I do not know exist the same parameters in OXO or not.
alarcos
It´s OXO with Audiocodes MP114vad wrote:excuse me - this is for OXE. I do not know exist the same parameters in OXO or not.
Hi Antonio,
The disconnection comes from OXO due to a "504 Gateway Time-out" error and later many "183 Session Progress" asks by the PXB.
Probably one parameter given by the MP about SDP is not compatible with OXO, and the negotiation is not completely correct and the communication is finally released (despite of being on call).
You'll have the translated version in your mail soon
OmniPCX Enterprise ACSE
OmniTouch ICS ACSE
OmniPCX Enterprise ACPS
OmniPCX Office ACSE
Alcatel-Lucent VAD
OmniTouch ICS ACSE
OmniPCX Office ACSE
Alcatel-Lucent VAD
alarcos
Thanks you for your reply!!!rubrio wrote:Hi Antonio,
