No icon on MyIC
No icon on MyIC
I have an issue with one laptop. We install MyIC and I can see the search bar but no MyIC icon on the clock side...Reinstalled, changed skin, etc. but doens't show anything...any idea what can this be? I'm using 6.6.000.106.b
Thanks guys
patmul39
Re: No icon on MyIC
Post by patmul39 »
I've installed that version a couple of times and never had that issue! Is it just on 1 laptop you're having the problem? I imagine you've already checked this but just in case not, is the icon set to "Always hide" in the taskbar notification?
Re: No icon on MyIC
Yep 1 laptop only. Already checked that :)
Will send it to format hehe
patmul39
Re: No icon on MyIC
Post by patmul39 »
Well you said it - format! :-)
seerawray
Re: No icon on MyIC
Post by seerawray »
I had the same problem on windows 7 and noticed that the ICON was hidden, I dragged beside the search bar.
Currently I do not have the lab for ICS but hope the screen shot helps. The man icon was there where the star icon is now in the attachment.
Re: No icon on MyIC
Was not my case...Thanks for the idea anyway
