Reload the VoiceGuides + Music on hold on the CPU6
Check the position of the main cpu with twin.
If the result for example is 20 then do a
rstdspcpl 0 20 1 -r
and don't forget to do a incout -3 before to get the errors messages on your screen.
This can take several minutes. THE MUSIC ON HOLD ON CPU CAN TAKE UP TO 20 MINUTES TO RELOAD !
ruud
reload music on hold
Post by ruud »
Has this command any effect on the running calls ? In other word, is there any interruption of the calls ?
Greetz , R
Nop
Return to “Usefull commands”
