Cannot connect to GD
wirtek
Post by wirtek »
Hello everyone.
I have just received an Alcatel OmniPCX Enterprise shelf and I cannot connect to GD. I am using a Serial-to-RJ45 cable connected to the "Config" port of the GD. I tried connecting via PuTTY Serial (COM1, 9600 Baud rate, 8 data bits, 1 stop bit, No parity, flow control none), it starts booting, but when it gets to the login sequence something goes wrong: I enter "mtcl", but when prompted for password, I cannot enter anything. I attached a capture of PuTTY terminal where you can see what happens when I try to connect.
Here is my cable wiring :
RJ45 <-> 9-PIN D-SUB
1 <-> 7
2 <-> 4
3 <-> 3
4 <-> n/a
5 <-> 5
6 <-> 2
7 <-> 6
8 <-> 8
Could the cause be the wiring? Could it be the software?
Thanks in advance.
Re: Cannot connect to GD
For GD - use login "admin" (not "mtcl").
wirtek
Post by wirtek »
Hi Vad, thanks for the prompt answer.
I tried with "admin" but it is still not working. I noticed that some "strange" characters appear during boot(you can see it in the snapshot I attached in the first post).. could this mean that the wiring is not ok(connection issues)?
Should I try connecting to other port on GD? or maybe on CS ?
Thanks!
If GD3 you can connect with root account, no password.
Regarding your terminal which is your configuration?
wirtek
Post by wirtek »
tot3nkopf wrote:If GD3 you can connect with root account, no password.
I don't know if it is GD3 .. :oops: how can I tell if it is ?
Regarding the terminal, I am currently trying to connect through HyperTermina(WinXP), the settings are: COM1, 9600 Baud rate, 8 data bits, 1 stop bit, No parity, flow control none.
Try x on/ x off for flow control.
GD can be: GD, GD-2, GD-3. It is written on the card. If it is a new system it should be GD-3.
wirtek
Post by wirtek »
I checked it and it is GD. It is an older system that has not been used for a while(a few years I think).
I tried with x on/ x off for flow control, but it is the same(not working). I am still worried about the "weird" characters that appear during boot(could they indicate a connection problem? ).
I also noticed some warnings during boot : I attached two snapshots so you can see.
rob b
Post by rob b »
Try setting the emulation to VT100, it looks like either a pinout issue or hyperterminal setting.
Cheers
enio.eltz
Post by enio.eltz »
It seems you have problems with cables and serial port. These weird characters can be both serial ports with problem or potencial difference due to ground.
About the message "warning: unable to open an initial console", this is normal.
Check your cables again. Another thing, where is call server hosted? CS, CPU-x or AS? If you use a CS board, it also has a config port, check this too.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
wirtek
Post by wirtek »
Hello everyone,
First of all, I would like to thank all of you for your post, they were of great help.
I finally managed to connect. I followed enio.eltz 's advice and connected to the CS board (the config port is the top right, although it is not marked :lol: ) and it works just fine. But first I had to move the CS board in the CPU slot of the shelf, because it was not getting any power. :oops:
Anyway, thank you all for your help.
Best regards,
Calin.
