8118 winpdm
dreyol
8118 winpdm
Hi!
I am trying to configure the first 8118 phone using winpdm. I have checked all TCs and Docs I could find, but i couldn't find the answer to the simple question: Where do i get the templates and parameter files needed for winpdm?
thanks in advance
thanks in advance
dreyol
Re: 8118 winpdm
Found it. The parameter definitions are included in the firmware files, which can be downloaded from the business partner site.
beirut
Re: 8118 winpdm
Hi, I am having the same issue, under which directory you were able to find the templates?
ysakaly
Re: 8118 winpdm
I will be very interested to have an answer to that point . very concerned about this on an install actually.
Re: 8118 winpdm
Depending of the image of the phones you has to add the parameter definition file (.pkg) into WinPDM. You have to unzip the phone Software and via File management - Add you search for the pkg-files for 8118 and/or 8128.
Only with the correct pkg-file you can config via WinPDM the phones.
Template is an other point. Templates where used to save offline a config for your installation - you can use template to quick config a lot of phones.
tzepf
Re: 8118 winpdm
is there anybody who can provide me with the png files for the 8118 and 8128?
Help would be appreciated.
Thanks,
Tobias
Thanks,
Tobias
Re: 8118 winpdm
for which phone software you need the pkg-files?
tzepf
Re: 8118 winpdm
SW Version is 6.0.8 and WLAN Version 3.7.b
Would be great if you have those.
Tobias
Tobias
Re: 8118 winpdm
I have tried to upload the files but it didn't work. Did you have access to the business portal? There you can download the firmware package 6.0.8. Within the zip you will find the pkg-files.
If not pls send me an PM.
sskar
Re: 8118 winpdm
Hi Silvio
Can I kindly ask you to send me parameter definition file (.pkg) for 8118 SW version 6.1.2 and WLAN version 3.7.c
Will save my life
sargsyan@rocketmail.com
Will save my life
