I have 4 no of 6850 switch stack in that my secondary switch was created .pmd files and rebooted again the following msg im getting in the console was given below please someone help me on this.
U-Boot (6.4.3.479.R01) (for OS6400, OS6850, and OS6855 platforms) (Mar 19 2010 -
17:59:35)
MPC8247 Reset Status: External Soft, External Hard
MPC8247 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8247 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel OS6850 (Kite II)
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
No environment variables found, using defaults
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
Device 0: Model: CF 64MB Firm: 20060729 Ser#: 2011B 0000455578
Type: Removable Hard Disk
Capacity: 62.5 MB = 0.0 GB (128000 x 512)
USB: scanning bus for devices...
USB device not responding, giving up (status=80000000)
0 USB Devices found
Hit any key to stop autoboot: 0
## Booting image at ff900000 ...
Image Name: miniboot-6.4.3.479.R01
Image Type: PowerPC VxWorks Kernel Image (gzip compressed)
Data Size: 984865 Bytes = 961.8 kB
Load Address: 00005000
Entry Point: 00005000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
## Ethernet MAC address not copied to NV RAM
Loading .text @ 0x01000000 (1580292 bytes)
Loading .rodata @ 0x01181d08 (337331 bytes)
Loading .data @ 0x011d42c0 (135644 bytes)
Clearing .sbss @ 0x011f54a0 (1528 bytes)
Clearing .bss @ 0x011f6000 (1571268 bytes)
## Using bootline (@ 0x4200): flash(1,0)cmm:default h=192.168.10.1 e=192.168.10.
1:ffffff00 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff f=0x0
## Starting vxWorks at 0x01000000 ...
USB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 562 Initialized
M824xHCI Controller found.
Waiting to attach to USBD...Done.
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
ataDrv call. 0 1 24 24 621 0 0
0xffffde0 (tRootTask): usbBulkDevInit() returned OK
CS EEPROM Module ID: 4201220f , System type: 48 port 1000Base-X, with 4 combo po
rts, stacking- kite2
Adding 5421 symbols for standalone.
Check Disk Running ...
dosChkLib : CLOCK_REALTIME is being reset to MON APR 23 13:00:54 2012
Value obtained from file system volume descriptor pointer: 0xed9b9d8
The old setting was THU JAN 01 00:00:00 1970
Accepted system dates are greater than THU DEC 27 00:00:00 1990
/flash/ - Volume is OK
Boot parameters are:
'flash(1,0)cmm:default e=10.255.24.81:ff000000 h=192.168.10.1 g=10.255.24.181 c
b=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.4.3.479.R01
VxWorks (for Alcatel CMM Motorola MPC8248) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Mar 19 2010, 18:00:20.
Copyright Wind River Systems, Inc., 1984-2006
CPU: Motorola MPC8248. Processor #0.
Memory Size: 0x10000000 (256 MB). BSP version 1.2/1.
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/K2os.img'...
6002176
Loaded 'alcatelNetworking_kernel.lnk' from '/flash/certified/K2os.img'.
Starting at 0x100000...
usbCbiUfiDevInit()Creturned OK
Adding 10619 symbols for standalone.
dosChkLib : CLOCK_REALTIME is being reset to MON APR 23 13:04:30 2012
Value obtained from file system volume descriptor pointer: 0xf58b2a0
AOS kernel version: 6.4.4.402.R01
Made on Oct 10 2011, 19:15:34.
Portions of code copyrighted by Alcatel-Lucent 1994-2011. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All r
ights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights r
eserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. Al
l Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
0xffffde0 (tRootTask): cmm_random_init OK
0xf577508 (tWhirlpool): batch_entropy_process called
Target Name: vxTarget
User: target
Attaching network interface lo0... done.
The current date and time is:
Coordinated Universal Time (UTC): MON APR 23 13:04:37 2012
Local time: MON APR 23 13:04:37 2012 GMT
Starting dynamic software load from '/flash/certified/'...
7fb0ceaeeef888ecbd7366e4c2381258691545d4
MON APR 23 13:04:49 : SYSTEM (75) info message:
+++ Switch Logging device '/dev/console' enabled for output
MON APR 23 13:04:49 : CSM-CHASSIS (103) info message:
+++ == CSM == === Chassis Supervision Starting Up ===
sysStartWatchdog() Starting watchdog timer to INTERRUPT after 240 secs.
Transferring crash data to a file ...
**** All the crash files are already available.Overwriting Crash4.pmd file ****
Transferring PMD done...
BCMINIT ERROR: Unable to find device profile for modType 4201220f device b500
Ni Sup & Prober: Exit code 6
Dumping PMD..... KITE/ETNA/GARUDA
tNiSup&Prb (de00ec8) @ 40 READY lckd=0 EE ME DS stk de00ec8-ddfe3d0
(de00e68) 327af4 327af4: fe2154()
(de00e28) fe2154 fe2154: fe37f0()
(de00e10) fe37f0 fe37f0: fe3c04()
(de00d90) fe3c04 fe3c04: 148068()
(de00d68) 148068 148068: 328e5c()
Writing PMD to flash ...size 259bytes and block 0
Writing PMD to flash ...size 882bytes and block 0
Writing PMD to flash ...size 1546bytes and block 0
Writing PMD to flash ...size 3671bytes and block 0
Writing PMD to flash ...size 3790bytes and block 0
Writing PMD to flash ...size 3856bytes and block 0
Writing PMD to flash ...size 5449bytes and block 0
Writing PMD to flash ...size 26001bytes and block 0
Writing PMD to flash ...size 26509bytes and block 0
Writing PMD to flash ...size 30165bytes and block 0
Writing PMD to flash ...size 47588bytes and block 0
Writing PMD to flash ...size 131060bytes and block 1
Writing PMD to flash ...size 262132bytes and block 2
Writing PMD to flash ...size 310445bytes and block 2
Dumping sys trace to PMD
Writing PMD to flash ...size 334865bytes and block 2
Writing PMD to flash ...size 343087bytes and block 2
Dumping ttall to PMD
Writing PMD to flash ...size 368023bytes and block 2
Dumping application data to PMD Start
cDumping application data to PMD Done
Writing PMD to flash ...size 385176bytes and block 2
Dumping spy report to PMD
Writing PMD to flash ...size 387850bytes and block 2
Completed PMD dump system rebooting...
ha
17:59:35)
- pci_clk 66666666
I2C: ready
DRAM: 256 MB
FLASH: 8 MB
In: serial
Out: serial
Err: serial
No ethernet found.
IDE: Bus 0: OK
0 USB Devices found
dosChkLib : CLOCK_REALTIME is being reset to MON APR 23 13:04:50 2012
6002176
dosChkLib : CLOCK_REALTIME is being reset to MON APR 23 13:08:24 2012
ights reserved
eserved
l Rights reserved
User: target
Coordinated Universal Time (UTC): MON APR 23 13:08:32 2012
Local time: MON APR 23 13:08:32 2012 GMT
MON APR 23 13:08:44 : SYSTEM (75) info message:
MON APR 23 13:08:44 : CSM-CHASSIS (103) info message:
Writing PMD to flash ...size 885bytes and block 0
Writing PMD to flash ...size 1549bytes and block 0
Writing PMD to flash ...size 3674bytes and block 0
Writing PMD to flash ...size 3793bytes and block 0
Writing PMD to flash ...size 3859bytes and block 0
Writing PMD to flash ...size 5452bytes and block 0
Writing PMD to flash ...size 26004bytes and block 0
Writing PMD to flash ...size 26512bytes and block 0
Writing PMD to flash ...size 30916bytes and block 0
Writing PMD to flash ...size 48339bytes and block 0
Writing PMD to flash ...size 311645bytes and block 2
Writing PMD to flash ...size 336065bytes and block 2
Writing PMD to flash ...size 344287bytes and block 2
Writing PMD to flash ...size 369223bytes and block 2
Writing PMD to flash ...size 386376bytes and block 2
Writing PMD to flash ...size 389050bytes and block 2
Ram
6850 Creates .pmd files and rebooting continously
lmherdvera
Re: 6850 Creates .pmd files and rebooting continously
Post by lmherdvera »
hi, i also have a switch getting this error..any help please...thank you...
try usb disaster recovery
Befor it you should format the filesystem.
interupt boot - start at miniboot
[Miniboot]-> diskFormat
[Miniboot]-> diskInit
[Miniboot]-> sysNewfs “/flash”
[Miniboot]-> reboot
You will find some hints for it in the forum.
[Miniboot]-> reboot
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
