HI guys,
Does any of you have some info on how to do this integration? Is it the same as with OCS??
Lync Integration
- cavagnaro
Lync Integration
- tot3nkopf
Re: Lync Integration
I have seen that Murray had some Lync integration. Better ask him directly. Also "search" returns many post on this matter
hi guy's, I did have a Lync connection as our office as the IS dept was trying to take over the telephony. they found that it was going to cost a fortune so they killed the server. all we had up to that stage was just SIP trunk routing calls between systems.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
