OmniPCX Recording - Silent monitoring not working
Jacob87
Post by Jacob87 »
Hello all,
I've been trying out this application, seems pretty good and easy to use. But there's always a catch ain't it :).
All is working fine except the silent monitoring, I just can't get it working. I click on the live call and all it does is, pops out the gif for streaming and I can't hear anything.
If you have any experience with this problem pls help.
Thx in advance for any idea.
krzysioD
Re: OmniPCX Recording - Silent monitoring not working
Post by krzysioD »
You mean alcatel omnirecord et all?
Pls give version of pbx, patchlevel and version of omnipcx record (tdm or ip?)
Jacob87
Post by Jacob87 »
I don't have a problem with the whole thing, just the Silent monitoring feature, which the agents in Recording use.
I use OXE R9.0 patch50a and I tried lots of versions of Recording now at 2.1.0.15. I'm trying it for IP calls only (IPDR).
krzysioD
Post by krzysioD »
Hm any incidents on pbx? capture csta dialog on pbx?
prasanna_s3
Post by prasanna_s3 »
this record will happen through G711 , could please change and check the user compressor
Jacob87
Post by Jacob87 »
No incidents, because recording works fine I can play the calls after they're completed, I just can't listen to them live in silent monitoring.
I can see csta dialog fine in audit log from the recording, don't know how to check it on pbx.
I don't think there's a problem with the PBX, because as I said the calls are recorded. Does the silent monitoring work fine for you ?
Jacob87
Post by Jacob87 »
I think i finally understand this silent monitoring should stream the call straight from the pbx and not from the Recording server.
Is that so ?
Jacob87
Post by Jacob87 »
Got it working, you were right it was the G711 after I configured it without compression it started working.
Thanks a lot for help. Both of you :)
prasanna_s3
poposami
Post by poposami »
I want to test the pcxrecord ,but the OPS has lock 130 set to 1.Whereas the document say lock 130 be 2.
Maybe because of that I dont see any recording in the search result.
Could anyone provide a working ops to complete the test.
Moreover,How to monitor the recording when log as admin?
Return to “OmniPCX Record”
