We are trying to install OXE R8.01 into an appliance server (IBM x3250 M3), unfortunately we encountered an error with this detail, "The Ethernet probed failed to find a card on your system. Press <Enter> to manually configure one.". After encountering the problem, we then tried to install a R10 and it was successful. We believe that the issue here is the driver of the Ethernet Card which is not included in the R8.01 installer but is available on the R10. Is our assumption correct? And if it is, would it be possible to update the drivers in the release 8.01 from the rivers in release 10? Or is there other way we could install the R8.01 into the said appliance server?
Thanks.
Best Regards,
Meynard
OXE R8.01 installation into an IBM x3250 M3
Re: OXE R8.01 installation into an IBM x3250 M3
I think can be some problem with M3 and R8.01
See the compatibilities (attached file)
Hi everyone.
I have a similar issue with an IBM x3250 M3 server. I need install oxe R8.0 into the ibm, but It is not possible.
Do you know the specific procedure for that.?
