IpTouch XML application - no HTTP request
vilem
Post by vilem »
We dvelopped XML application for IP phone menu.
The application is called from telephonic context (display available during telephone call). In our lab works well.
But on customer site we had to call this application from main menu (we moved application menu item from telephonic context to main menu). When calling this application from telephonic context there was no application HTTP request generated on the side of PRS.
Does anyone know where is the problem? Versions PRS or....?
Thanks.
Re: IpTouch XML application - no HTTP request
PRS versions can be the issue as the context were introduced on last versions of PRS, so if you are using on customer an oldy one then better upgrade
vilem
Post by vilem »
Info from customer: PRS – 4.1.0.3.8 ICS 6.6.000.106b
Our lab versions: PRS - 4.1.0.3.8 ICS 6.5.001.105.d
Any idea? Vesion of OmniPCX?
OXE acts only as interpreter...
The application was set as public or private? COS on the phones?
vilem
Post by vilem »
Here is COS on the IPTouch phones. Is it that? What item should I try?
Is there any other configuration, for example for PRS?
Return to “IpTouch Phones XML Applications”
