Configure a GD3 over SSM?
IP Security in general, Thales boxes, SSM (Server Security Mode), MSM (Media Security Module), etc....
Mati
Post by Mati »
I have common Hw configuration with 4 MG (one is local), all of them with GD3. The problem is that I have only 3 licenses for SoftMSM… How can I get the security on the fourth equipment?
In OPS seem that the local GD3 has to go over the SSM… I tried this in the office with a GD and works OK, the problem cames with the GD3, I can't define it as GD, how can I configure it?
In addition I have a 4645 on another CS over a MMS.
prasanna_s3
Re: Configure a GD3 over SSM?
Post by prasanna_s3 »
what type of mms is that
if u have rack mountable MSM , u can utilize for application and GD .
Mati
Post by Mati »
Yes it's a MSM-RM (Rack)
I've tried to conect the GD3 to the MSM and then to the SSM(as the OPS shows).
On the GD3 config, I put it as "Protected, No SoftMSM". On the comm server on "secured IPs" of the GD I apoint to the MSM and it doesn't wake UP; but if I apoint to the SSM it goes UP then the signaling is ok but the voice not (I can do a Call but I don't understand nothing).
Another question, this is absolute QoS transparent, or not?
krzysioD
Post by krzysioD »
Mati wrote:I have common Hw configuration with 4 MG (one is local), all of them with GD3. The problem is that I have only 3 licenses for SoftMSM…
And what does ALU say about it? AFAIR one license == one SoftMSM == one GD3 or one INTIP3.
Mati wrote: In OPS seem that the local GD3 has to go over the SSM… I tried this in the office with a GD and works OK, the problem cames with the GD3, I can't define it as GD, how can I configure it?
Strange - any pic of this config/ops?
And another 4645 needs a MSM - this is VoIP voice mail and just like GD/GA or INTIP/INTIP2 talks encrypted voice thanks to MSM.
Mati
Post by Mati »
The licneses are (In Spanish):
Software OmniPCX: Servicios de seguridad
1 3BA09078JA Cifrado del servidor
1 3BA09079JA Cifrado del servidor para 500 usuarios de IP
3 3BA09249JA Licencia de software Media Security Module para 3 MediaGateways IP
1 3BA27698AA MÓDULO DE SEGURIDAD DE SERVIDORES RM (SSM-RM) para cifrado de voz.
1 3BA27699AA MÓDULO DE SEGURIDAD DE MEDIOS RM (SSM-RM) para cifrado de voz.
And the THALES.txt file is:
Caja SSM/MSM : SSM-RM (1)
| Placa | Posición |
| CS | 1.8 |
| GD-3 | 1.0 |
| GA-3 | 1.1 |
Caja SSM/MSM : MSM-RM (2)
| Placa | Posición |
| 4645-2 | 18.0 |
krzysioD
Post by krzysioD »
And you personally configured this Actis offer?
Mati
Post by Mati »
nop,
Actis's offer was configured by a presseller. I ask him and he told Actis never Wrong... I don't Know the Actis part and how it works.
I guess he will have to add another license SoftMSM, because now it works, just that there is a module that does not work( it doesn't have service yet).
Anyway thank you very much, and I will tell you what's new.
krzysioD
Post by krzysioD »
Actis - is many times wrong. It says where to mount CPU...
So many times - even placement of cards - was not optimal.
Actis is good for small configs or usual config. Thales and softmsm is not very common or usual.
Actis could order for you batteries from ALU factory and PC from HP just to go through ALU, or cables for other market.
But it should be your presale and Business Partner here asking - not you./
Return to “IP SECURITY / ENCRYPTION (Thales)”
