When forward to PO/Attendant 4059 => communication broken
Czar666
Post by Czar666 »
I have an issue in a company who is forwarding a ip phone to the 4059.
If 4059 is free => then everything ok, call is forwarded and person can answer the forwarded call.
If 4059 is busy => call is broken after few seconds (you just can hear the welcome message). In fact communication should go to music on hold.
Anyone an idea where I have to start searching?
Thanks in advance.
Re: When forward to PO/Attendant 4059 => communication broke
What about usual incoming calls to attendant - no problem with free or busy state?
Czar666
Post by Czar666 »
Hi Vad,
Thank you for your reply. I asked the customer to do this test this afternoon. I'll keep you informed about the result.
Czar666
Post by Czar666 »
Customer replied that it works again.
Thanks anyway for the help.
