problem in oxo
alcarex
problem in oxo
Post by alcarex »
hi guys
i am facing problem of auto callback(redial) of last external num dialed twice a day .(8:48pm & 11:48 pm) when the call lifted it gives sounds like alarm of a clock
can anyone help in this regard system is oxo ver 5
et
Re: problem in oxo
Post by et »
Try to specify your question more clearely. Callback and redial - different functions. What do you mean?
alcarex
Re: problem in oxo
Post by alcarex »
et wrote:Try to specify your question more clearely. Callback and redial - different functions. What do you mean?
the problem is autoredial,the last external num dialed from extns will get dialed automatically by the system .i had given a clod reset but the problem still persist.the lines used are analog lines connected to a APA card
Return to “MAIN”
