Nx64 Card setup
m.macdonald
Nx64 Card setup
Post by m.macdonald »
I am having trouble getting this to work.
I have installed the card - setup 2 data terminals - remote end set to semi permanent and the call appears to be made.
Config 2 shows the remote shelf with free / avail chans this shows 14/30 which would indicate that there are channels used.
However the router connected to the ports does not come up and the control leads on the serial port do not show the up status.
Any help gratefully received
Mike
Return to “GENERAL”
