4504 controller
ram
4504 controller
Hi ,
What is the procedure to break or reset the password in omniaccess wlan controller 4504.
Please some one help me on this it's urgent.
Ram
Ram
jlettinck
Re: 4504 controller
Hi Ram,
Could you try the following using the console cable:
User: password
Password: forgetme!
(OAW4308) > enable Password: enable
(OAW4308) # configure terminal
(OAW4308) (config) # mgmt-user admin root password # ********* Re-type password # ********
(OAW4308) (config) # exit
(OAW4308) # exit
(OAW4308) > exit User: Then login with username admin with the password you used.
The Enable password is set to "enable"
Please let us know if it worked for you.
Good luck
User: password
Password: forgetme!
(OAW4308) # exit
Good luck
ram
Re: 4504 controller
Hi jLettinck,
Thanks A lot man I will try this. as of now we are using Ap61 access point now we are going to implement 4 no of Ap 105 access point we have enough license in the controller. is it Ap 105 will Compatible For 4504 controller . Please Let me know .
it's urgent. we have to choose the product that will compatible for 4504 controller.
Ram
Ram
jlettinck
Re: 4504 controller
Hello Ram,
All the AP's are compatible with the OAW-4504 controller. The AP-6x series are end of life, however still supported on the latest 6.1.x release, so there should be no problem should you upgrade.
The AP-105 is absolutely supported.
Best regards,
Jeroen
Best regards,
Jeroen
ram
Re: 4504 controller
Hi Jlettinck,
I am waiting for client confirmation to break the password in controller.
If i break the password in 4504 controller means is there any chance to losing my current configuration...?
Kindly let me know .
Ram
Ram
jlettinck
Re: 4504 controller
There will be no loss of configuration. You just reset the admin account password.
ram
Re: 4504 controller
Hi Jlettinck,
Thanks a lot man , we are successfully reset the password.
whether his method is applicable for all wlan controller ...?
Ram.
Ram.
Re: 4504 controller
Is Hewlett Packard AP (Model: APIN0207) compatible with 4504-XM WLC? Thanks in advanced.
