Hi all
I searched and found some topics about call filtering but there are not success.aslo I read all of them and document.
now I want to configure this structure ,please help me?
I have ISDN line with number 888 and my ISDN provider just send me 888.in this case when I want call to this number from outide:
my number (home) 1234567 and dial 888 and rings on hunt groups.it works good but when I want to filter special caller id it dose not follow structure that mentioned on Documents or ALU posts.is there an option that I check it?or.....
actually I want ,when I call to this number(888) the system detect my caller id and send me to special extension.
please share your experience.
Route Special Caller ID number " FILTER"
Re: Route Special Caller ID number " FILTER"
Up to OXE R5.1.1 the Overflow Directory number must be Monoline.
From R5.1.1 you can use Multiline too.
888 - Nb to be filtered from external
1888 - Routingnummer (Internal)
200 - destination DN if known caller
250 - destination DN if unknown caller
1234567 - Caller nummer
1 - Index of Filter
1. Create 888 / 1888 in the DDI Translator
First External Number : 888
First Internal Number : 1888
Range Size : 1
2. Under Translator - Called Filtered Number create the 1888 (Default Entity)
3. Under Translator - Called Filtered Number - Teleservice Filtering die
Create a Filtertable with Index 1 with Overflow 250
=> Dest. for unknown caller
=> Consult/Modify: Teleservice filtering =>
Directory Number : 1888
Filtering parameters
ISDN Teleservice Phone
Status Night
Filtering Index : 1
Overflow Directory number : 250
4. To be filtered DN (here 1234567) must me configured in speed dial range
Consult/Modify: Abbreviated Number
Range Number : 1
Abbreviated No. : 00
Call Number : 01234567
5. Abbreviated Numbers by Range => Godown - Caller Number Filtering enter the Nummer for the destination for this user
Consult/Modify: Caller Number Filtering
Range Number : 1
Filtering index : 1
Routing Number : 200
1 - Index of Filter
Range Size : 1
Status Night
Filtering Index : 1
Range Number : 1
Range Number : 1
Filtering index : 1
thanks a lot for your reply.
just 1 question what you mean about routing number 1888??
Could be 888 of course. It's your internal DN for the called filtered number.
Does this methode block a specific number ringing into the system accross all of the DDI range or is it for just one DDI number?
Peter
Peter
this works absolutely marvellous. and the possible complexities are breath-takin' - but still easy to setup and free of licence.
Hello.
Eliot followed the step by step of programming.
But my system did not filter the connection, sending the number only for Teleservice filtering overflow number.
What could be wrong?
Thanks for the help.
Wrong? I think speed dial by range management (call number in SD and external callback translation).
Calling number not recognized by system.
How to check - create Direct SD (with any prefix), manage call number and directory name. Make incoming call from this number.
If you see name (from SD) - management Ok. If you see only number - Caller Id not recognized in SD.
