ERP with 4 Ring ( Network Loop Problem )
koto
Post by koto »
Dear All,
I have critical case with ERP ( 4 Ring ). From this forum and AOS manual i read the example for erp.
I tried config ERP with vlan stacking or vlan standar.
The problem is network looping make my switch drop (RTO).
You can see the topology on the attachment ( split to 2 ring )
Note : on the topology, I used stacking vlan. from the same topology i tried to use vlan standard. With stack vlan or standard vlan I met a same problem (network Loop).
Please your advice how to handle multiple ring and network loop on ERP environment.
Regards / Henrizal Koto
koto
Re: ERP with 4 Ring ( Network Loop Problem )
Post by koto »
Is there anyone experienced with this case ?
Please your help
cedric1
Post by cedric1 »
hello
You are in limitation of ERP design. So your design doesn't fit in what we can done with ERP.
As you have connectivity between all devices make so a real ring 1 only.
See picture for correction.
So delete ring 2 .
Use only ring 1.
Delete link between SW3 and SW4
All will work fine.
Cedric
jlettinck
Post by jlettinck »
If I am correct, "multiring" support will be available later on this year.
eizens
Post by eizens »
In the network configuration manual is clearly stated:
• Only a single node can be shared between the ERP rings; multiple shared nodes could result in a loop, if
the rings that are configured on shared nodes have common protected VLANS.
So your result is expected. Use one ERP ring as adviced and everything will be OK.
Eizens
FavaleSimone
Post by FavaleSimone »
Hi, how many node it's possible include in a single ring topology ?
jlettinck
Post by jlettinck »
By default in a single ring you can have 16 nodes.
1 single node can participate in a maximum of 8 rings.
FavaleSimone
Thank you very much.
FavaleSimone
Hello, i have attach a image with a topology network.
It's possible create this configuration or some loop might be created ?
Thank you in advance for your help ?
Simone
FavaleSimone
the previous post with the attached refers to 6855 and 9700E devices with ERP version one and each ring transport the same vlan
Return to “OmniSwitch 6855”
