Soundstation2W Caller Id
pmaes
Post by pmaes »
I’ve just successfully registered two Soundstation2w to our dect system.
They work just fine but I seem to have a problem with the caller id on the Soundstation.
It does not show the number. Caller id is set to on on the Soundstation.
The user created for this is a Gap Handset, GAP+ wouldn’t stick.
Does anyone have any experience with this issue?
Patrick
Friday
Re: Soundstation2W Caller Id
Post by Friday »
Maybe you have registered the Soundstations in Basic mode?
Just uassign the sets and start the registration procedure again. Click the Modfy Mode button to choose enhanced mode.
pmaes
Post by pmaes »
I can't find a enhanced mode on the set, there is just the choice "Register" or "GAP"
Friday
Post by Friday »
See OMC -> Uses/Base stations list -> GAP-reg. -> Modfy Mode button.
You will have to unassign the set and start the registration procedure again. Then you will be able to choose Enhanced mode (in OMC)
pmaes
Post by pmaes »
I'm using Omnivista 4760 (4760.5.1.06.03) on R9.1-i1.605-27-be-c0
Friday
Post by Friday »
R9.1 is OXE
This forum is OXO. Try to post in OXE forum.
Return to “PWT/DECT System”
