linking a HP C7000 with flexfabric module
ydeschoe
Post by ydeschoe »
Gents,
does anybody have any experience with setting up a HPc7000 blade enclosure with 2 FlexFabric modules to a MC-LAG setup of 2 10K switches
following the HP guide from the moment you please 2 links inside the Same Shared uplink set (SUS) it will use the LACP protocol to establish a link.
Now I'm using 2 10G links inside the same SUS on the same module but the LACP (MC-LAG) doesn't come up on the 10K switches, the status from the LACP is on RESERVED, no idea what this mean.
What I also see on the GUI from the flexfabric cards is that the links are in active/standby iso active/active. The links have also a different LAG ID on the same card, following the guide they should have the same LAG ID.
Thanks for you response
Yves
cedric1
Re: linking a HP C7000 with flexfabric module
Post by cedric1 »
hello
I have no experience with 10K and MC-LAG, but did you try to make a simple config with a lacp on on switch only.
If it is ok, MC-lag should be transparent to your hp system
Cedric
devnull
Post by devnull »
From my experience (MC-LAG with 6900) Cedric is right. From the "Edge side" you should only have a plain normal LACP.
Works here with ALU Stacks and Cisco connecting to a MC-LAG on 6900s, I have no HP...
MC-Lag is working in general?
ydeschoe
Post by ydeschoe »
All,
seems to be a known problem
There is a sync problem between HP and device and 10K.
This should be solved after a software upgrade which we plan after our IT freeze in the middle of January.
The problem is known also on the 6900 MC-LAG setup by Alcatel.
I will keep you updated after the upgrade
Yves
cedric1
Post by cedric1 »
hello
Yes it is what i listen from other collegue.
Fix is available as i heard.
Cedric
ydeschoe
Post by ydeschoe »
After the upgrade of the AOS we are now able to connect HP Flexfabric Modules in a MC-LAG setup to the 10K switches.
problem solved
Yves
devnull
Post by devnull »
Which release are you using?
ydeschoe
Post by ydeschoe »
We are running now the following soft release
OS10K 7.1.1.1736.R01 Service Release
This version is not available on the portal for download, you need to obtain it via your support contract
yves
Return to “OmniSwitch 10k”
