This is a quick explanation on how to setup ubiquity.
You will need the license for this to work, of course...
Ubiquity setup
- frank
Ubiquity setup
Re: Ubiquity setup
صباح الخير سيدي انا من الجمهورية اليمنية لدي سنترال الكاتل 4200e اريد دليل المستخدم لكي اعرف ادارة السنترال وتغير الترقيم الداخلي للسنترال هل يمكنكم ارسال كتاب الدليل لي وشكرآ
Re: Ubiquity setup
I speak Arabic, but I want Acunnina User Guide Cattell 4200e want to modify the internal numbering in Central to comply with rooms Dahl figures the hotel I work in a modest tourist hotel in the city of Green Allaa in Yemen happy I will be grateful to you for help
Re: Ubiquity setup
- cavagnaro
Re: Ubiquity setup
Change internal numbering plan? Not a simple task...you need to redo almost everything from users to direct routing. Better hire some expert
